Wierd noise comming from my speedometer? #692753
05/08/10 09:49 PM
05/08/10 09:49 PM
Belleville Il
Dingmaster Offline OP
Belleville Il
While driving my 71 Charger suddenlly the speedo in the rallye cluster will start making a high pitch grinding noise. the needle will bounce higher, suddenly jumping from around 45 to 70-80 MPD.
Is the problem with the speedometer? It seems to do it less the more I drive it.
Anyone have this problem?
Re: Wierd noise comming from my speedometer? [Re: Dingmaster] #692754
05/08/10 09:53 PM
05/08/10 09:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sounds like you need to remove the speedo cable core to clean and lube it.
Re: Wierd noise comming from my speedometer? [Re: stumpy] #692755
05/08/10 09:56 PM
05/08/10 09:56 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
