Mopar intake manifold choke well #692686
05/08/10 08:54 PM
05/08/10 08:54 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hello everyone! I'm putting a 70 Challenger together with a 383. Fresh engine. I had wanted to use a Performer RPM with a Demon carb. Well, this set-up hits the hood! So, Ive bought a Mopar performance dual plane intake. My question is, what to do with the choke well opening???? It is clearly open to the exhaust cross-over. Do I make a plate to seal the well opening? What do others do? Take care!! Jeff
Re: Mopar intake manifold choke well [Re: 1969RR] #692687
05/08/10 09:59 PM
05/08/10 09:59 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
I put the choke well with a new gasket on and bolt it down. You can make a plate.
Re: Mopar intake manifold choke well [Re: NITROUSN] #692688
05/09/10 09:49 AM
05/09/10 09:49 AM
N. Dak.
RareTA Offline
super street
RareTA  Offline
super street
N. Dak.
Since I only use my cars when it summer I use and piece of flashing tin and block off both sides of the intake at the heads. That way the intake doesn't burn the paint off or on aluminum intakes turn them brown.
'09 Challenger R/T '70 Challenger T/A 340 6Pak and Auto I was born with nothing and I still have most of it left!
