Re: Disassembly of BB 727
[Re: moparman89]
#692588
05/08/10 07:46 PM
05/08/10 07:46 PM
If you've never done it before, get a good service manual.
The first step is to take the front pump housing out of the case. It's a little tricky in that you need to thread bolts into two holes and use some type of slide hammer or chain to break most of them free. From there I usually pull the pan off and the valvebody out, then loosen the front band and pull the clutches, planetaries etc. out.
[Re: moparman89]
#692592
05/08/10 09:50 PM
05/08/10 09:50 PM
RapidRobert
1st put a dial indicator on the input shaft and measure your end play and write this dimention on th inside bell face w a magic marker as you'll need to refer to it later. I'd clean the exterior case absolutely squeaky clean right off the bat before you start teardown. (trust me on that one)
[Re: moparman89]
#692596
05/09/10 01:14 AM
05/09/10 01:14 AM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Here's the rock bottom easiest way to pull the front pump! ![](http://i169.photobucket.com/albums/u237/BuiesCreek847/Trans%20Rebuild/RemoveOilPump.jpg) Run a 3/8" bolt into the larger bolt hole. Stuff a big wrench under the head of the bolt. Notice the pointy bits of the open end wrench hit the case? Give 'er a tug and out it comes. You might have to do it on both sides but it sure is quick and easy.
[Re: feets]
#692597
05/09/10 01:33 AM
05/09/10 01:33 AM
Thanks, feets, looks like a good idea!
[Re: moparman89]
#692600
05/15/10 05:38 PM
05/15/10 05:38 PM
Take all the bolts out of the tailshaft housing that attaches it to the main case.
Then take out the two phillips head screws on the bottom of the tailshaft housing and remove the metal plate that they hold in. That will give you access to a large snap ring that goes around the big bearing on the rear tailshaft. While spreading that snap ring apart, you should be able to pull the tailshaft housing off the tailshaft.
[Re: dirtybee]
#692602
05/15/10 07:19 PM
05/15/10 07:19 PM
Posts: 12,326 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
It's a little late now for this dis-assembly, but I just remove the valve body and tap the front pump housing out from the back with a punch and hammer.
Master, again and still
[Re: DaveRS23]
#692603
05/15/10 09:05 PM
05/15/10 09:05 PM
Posts: 15,487 Florida
scratchnfotraction
turn it upside down on the bell end with all the pump bolts removed now lift it a couple inches and slam it back down the pump with fall out ![](/ubbthreads/images/graemlins/laugh2.gif) sound like he is scraping the tranz and needs the steel seperated form the aloonyum ![](/ubbthreads/images/graemlins/shruggy.gif)
