Re: willwood brake hats?
[Re: Quicktree]
#692489
05/08/10 08:21 PM
05/08/10 08:21 PM
Posts: 1,404 Chesterfield Twp. Mi.
John Burdine
why would you want to
2 reasons, 1. to pull the tire in just a bit more (not critical though).
2. to use the shorter 2" drive studs which i have instead of the 3" and a long spacers. (also not critical).
[Re: John Burdine]
#692490
05/08/10 08:43 PM
05/08/10 08:43 PM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
You are talking 1/2 thick where they go over the studs? Thats very thick.
Yes,
this brake kit is for big ford housing ends.
As said you could call wilwood and ask. I dont think taking .125 off the face would hurt or compromise the rotors strength.
[Re: MRMOPAR]
#692493
05/08/10 09:12 PM
05/08/10 09:12 PM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
I'll have to check my hat # in the next few days While mocking up the rear for the rampage, I also need more thread engagement. the lug nut face is .560" at the washer with .330" thread in
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
[Re: John Burdine]
#692495
05/09/10 06:34 AM
05/09/10 06:34 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
i'm not making it up, willwood rear brakes p/n 140-0262-BD the hats are 1/2" maybe closer to 9/16".
You are correct,those hats are for Ford 8"and 9" and are actually .630 thick including the champher.I still would be hesitant to cut them,especially if your using stock studs that pertrude through axle flange.
[Re: B G Racing]
#692496
05/09/10 10:39 AM
05/09/10 10:39 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I also have the thick Willwood hats. Look around to see who makes a steel hub. They should be much thinner.You will have to figure out the difference in rotor placement to fit the caliper and adjust, but maybe with some luck, a set of hubs, and maybe rotors, you can gain 3/8 to 1/2 inch. I was considering it if I redo my chassis for more tire.
[Re: gregsdart]
#692497
05/09/10 11:02 AM
05/09/10 11:02 AM
Posts: 4,991 new jersey usa
11secdart
new jersey usa
I have two sets of Wilwood hats I bought and couldn`t use for an 8 3/4, one set is machined and one isn`t they are also drilled for 5/8 studs. If anybody needs them or wants to try them let me know as I have no use for them.
