floor pan install question
#692141
05/08/10 09:17 AM
05/08/10 09:17 AM
Posts: 1,472 Overland Park, KS.
Joshs68
Overland Park, KS.
I have floor pans that I am going to install in my 67 barracuda. They are the individual pan/floor mat style. I test fit them and I am very happy with the fit. I was going to put them in tight and mark the edge, cut out the floor and weld in the pan. My question is can I cut the floor long so I have a half inch overlap, drill holes in the perimeter of my pan and spot weld it then seam sealer it or is that cheesey? I thought this may make it easier to position the pan while I tack it in. Or should I cut the whole the same size and weld the complete seam?
Re: floor pan install question
[Re: Mopar Grandpa]
#692146
05/08/10 12:40 PM
05/08/10 12:40 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
A job worth doing is worth doing right. Do not overlap, butt weld and grind. Yes it will take longer but the finished product will be done properly. And don't forget that someday you will sell this car. Don't have a buyer walk away because of a quick fix.
How is an overlap joint a "quick fix"? In the welding industry, its considered a stronger joint. Any butt welds we did, almost always got a backup strip or ring for strength. I understand making it like a factory joint but done right, a lap joint could still look correct. Just say'n'...![](/ubbthreads/images/graemlins/beer.gif)
[Re: Scott Carl]
#692147
05/08/10 12:46 PM
05/08/10 12:46 PM
Posts: 93 New York
tt455
New York
Absoultly,mine aren't going anywhere.
[Re: Scott Carl]
#692149
05/08/10 03:05 PM
05/08/10 03:05 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
butt welds are for exterior skin panels where you'd have to deal with feathering out the overlap if you didnt butt weld. Nothing wrong with using an overlap joint for a floor pan. Save the unnecessary labor there for the ext panels where it counts visually. ![](/ubbthreads/images/graemlins/thumbs.gif)
