SB Intakes #691829
05/07/10 08:50 PM
05/07/10 08:50 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Anyone have any real world experience on the Edelbrock Performer RPM, Edelbrock Performer RPM Air Gap and the Edelbrock Torker II? Whats the main difference between the RPM and the RPM Air Gap? Also would it be better to chose the torker II since its a single plane, or for my combo is a dual plane better suited? Leave at 2400-2600, shift at 6100, traps at 6200.
Post deleted by Defbob [Re: DusterKid] #691830
05/07/10 09:06 PM
05/07/10 09:06 PM
Re: SB Intakes #691831
05/07/10 11:54 PM
05/07/10 11:54 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It all depends on your combo but for an all around street/strip intake on a mild to moderately built SB the RPM Airgap is a winner (it trumps the regular RPM by a few HP due to a cooler charge because of the air gap under the intake).
Re: SB Intakes [Re: DusterKid] #691832
05/08/10 01:42 AM
05/08/10 01:42 AM
Alberta Canada
StrokerAspen Offline
Alberta Canada
I have used the RPM Air gap on a few different combos. I was very pleased with the performance from it. I used it on my 340, and the total combo had a nice power curve right to 7000rpm. We have also used it on a 434ci. It STILL worked to 6300rpm on that engine! I was quite surprised!
I have not had any personal experience with the performer RPM, or the Torker II. From the looks of it, the performer RPM has the same runners as the air gap.
however, if you are set on running a single plane, the Torker II would not be my first choice. From what I have seen on here, and I will be testing personally, the victor manifold is a much better single plane intake. Last year, I ran a Super Victor, and I was quite happy with the performance from it as well.
Re: SB Intakes [Re: StrokerAspen] #691833
05/08/10 07:47 AM
05/08/10 07:47 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
We played with a tq 2 and a air gap on a 360, air gap worked better, tq2 with a 750cfm air gap with a 850cfm annular, 10.5 motor with a hyd roller in the 230s@ .050 with a 3k vert, pulled to 6500 with good bottom end
Re: SB Intakes [Re: emarine01] #691834
05/08/10 11:28 AM
05/08/10 11:28 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I went from a t-2 to a victor 340 and picked up 3 tenths.Both intakes had work done.
Re: SB Intakes [Re: DusterKid] #691835
05/08/10 12:49 PM
05/08/10 12:49 PM
Beavercreek, Ohio
OA5599 Offline
OA5599  Offline
Beavercreek, Ohio
Very happy with my RPM. Much more impressive than the LD340 I had. Air Gap is worth about 5hp at the flywheel and I was going to go with it, but found an outstanding deal on an RPM that didnt make 5hp worth the extra $$$.
Re: SB Intakes [Re: OA5599] #691836
05/08/10 03:57 PM
05/08/10 03:57 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I have run both the RPM and the RPM Air-gap on my old 360 combo...I did not see any difference between the two...both worked VERY well.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: SB Intakes [Re: FlyFish] #691837
05/08/10 04:06 PM
05/08/10 04:06 PM
Locomotion Offline
Locomotion  Offline
Internally, they are the same manifold.
The Air Gap may be a little more tempermental in cold weather but, jetted correctly, should make a few HP more due to the air gap.
Re: SB Intakes [Re: Locomotion] #691838
05/08/10 04:16 PM
05/08/10 04:16 PM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
The AG worked very well on my 360 and even on my 408 till i swapped it out for a Super Victor.I was so happy with the Air Gap that i didn't even sell it after the SV purchase.I can always use it again somewhere else.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: SB Intakes [Re: 77DragracerR/T] #691839
05/08/10 04:27 PM
05/08/10 04:27 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
and how is that SV working out?
Tony
70 AARCuda Vitamin C
Re: SB Intakes [Re: 70AARcuda] #691840
05/08/10 04:32 PM
05/08/10 04:32 PM
Keymar, MD
Keymar, MD
anyone use any of the weiand intakes or everyone pretty much still with the proven edelbrock intakes?
Re: SB Intakes [Re: DusterKid] #691841
05/08/10 05:29 PM
05/08/10 05:29 PM
Locomotion Offline
Locomotion  Offline
I compared the Weiand Stealth to a Holley Strip Dominator one weekend and they were close. The Holley was a little bit better on my particular application probably because once my converter flashes, the engine rpm's never go below 4,900, even on a hot, "bad air" day. I shift around 6,700 and run a lot of gear, converter and cam duration with OEM 1.88" heads on a 360. 11.31 @ 115 best at 3,540 lbs.
Each combo will be different.
A dual plane would be better for the original poster. But it would help to optimize jetting for each intake tried because they can be different. Just swapping intakes doesn't always give an accurate comparison.
Re: SB Intakes [Re: Locomotion] #691842
05/08/10 05:41 PM
05/08/10 05:41 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I was hesitant to use the air gap because its a dual plane because my ride has some gear to it, but I have to say between the T2 and the AG, I am really impressed with AG. I did mod mine a little, and that's when it really started to work. I added a blended 1" spacer and modified the divider some, and its now much better with my annular 800cfm carb and it pulls really hard now.....Althought I am switching over to efi, the intake and carb could be for sale.
Re: SB Intakes [Re: DusterKid] #691843
05/08/10 07:11 PM
05/08/10 07:11 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My old 340 went low 7.20s with a Weiand
X-Celerator in my 3300# Dart. It had good bottom end too, the cam was a Hughes hydraulic 237/242 @ .050 with .586/.592 lift.
Re: SB Intakes [Re: 70AARcuda] #691844
05/09/10 11:32 AM
05/09/10 11:32 AM
Burlington,Ont.
Burlington,Ont.
Car went from 11.01 with AG to a 10.76 with SV but the weather had greatly improved on the new times but the 60's were consistant 1.42 from 1.47.
Re: SB Intakes [Re: 77DragracerR/T] #691845
05/09/10 01:26 PM
05/09/10 01:26 PM
Milledgeville, (central) Georg...
Bighead440 Offline
Bighead440  Offline
I too have run the TorkerII, the AirGap and M1 single plane on a couple of small blocks, to see which one was better. The first was my 3100lb Demon with a 360, KB107 pistons, MP .528" mechanical cam (w/1.6 rockers-.563") and unported 2.02x1.60" "J" heads. The car ran the exact same MPH (109)but was overall quicker (60ft much better with RPM AG) comparing the RPM AG to the TorkerII. On the street the RPM was hands-down better at part throttle, which made me like it best. Then on a 416 with 10.5:1 compression, Ultradyne solid .590" cam and OOTB Eddy heads (Comp 985 spring, 10deg lock upgrade) in the same car with the M1 SP as the baseline, I STILL got a 60ft boost but the same MPH (118)with the switch to the AG RPM. I attribute this to the low rpm nature of the 4" stroke motor with mild flowing heads. I think the M1 SP might MPH better on a 3.79" stroke motor, or with Indybrocks or Large Port Commandos on the same 416" shortblock. Now I am putting a 13:1 416 in the same car with a fully ported set of Indybrocks, a Lunati solid roller and a Super Victor , wonder if the RPM AG would pick it up as well..? RB
