Post deleted by Defbob
[Re: DusterKid]
#691830
05/07/10 09:06 PM
05/07/10 09:06 PM
Re: SB Intakes
[Re: DusterKid]
#691832
05/08/10 01:42 AM
05/08/10 01:42 AM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
I have used the RPM Air gap on a few different combos. I was very pleased with the performance from it. I used it on my 340, and the total combo had a nice power curve right to 7000rpm. We have also used it on a 434ci. It STILL worked to 6300rpm on that engine! I was quite surprised!
I have not had any personal experience with the performer RPM, or the Torker II. From the looks of it, the performer RPM has the same runners as the air gap.
however, if you are set on running a single plane, the Torker II would not be my first choice. From what I have seen on here, and I will be testing personally, the victor manifold is a much better single plane intake. Last year, I ran a Super Victor, and I was quite happy with the performance from it as well.
Re: SB Intakes
[Re: FlyFish]
#691837
05/08/10 04:06 PM
05/08/10 04:06 PM
Posts: 5,894 Florida
Locomotion
I have run both the RPM and the RPM Air-gap on my old 360 combo...I did not see any difference between the two...both worked VERY well.
Internally, they are the same manifold. The Air Gap may be a little more tempermental in cold weather but, jetted correctly, should make a few HP more due to the air gap.
Re: SB Intakes
[Re: DusterKid]
#691843
05/08/10 07:11 PM
05/08/10 07:11 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
anyone use any of the weiand intakes or everyone pretty much still with the proven edelbrock intakes?
My old 340 went low 7.20s with a Weiand X-Celerator in my 3300# Dart. It had good bottom end too, the cam was a Hughes hydraulic 237/242 @ .050 with .586/.592 lift.
Re: SB Intakes
[Re: 70AARcuda]
#691844
05/09/10 11:32 AM
05/09/10 11:32 AM
Posts: 1,613 Burlington,Ont.
77DragracerR/T
Burlington,Ont.
The AG worked very well on my 360 and even on my 408 till i swapped it out for a Super Victor.I was so happy with the Air Gap that i didn't even sell it after the SV purchase.I can always use it again somewhere else.
and how is that SV working out?
Car went from 11.01 with AG to a 10.76 with SV but the weather had greatly improved on the new times but the 60's were consistant 1.42 from 1.47.
Re: SB Intakes
[Re: 77DragracerR/T]
#691845
05/09/10 01:26 PM
05/09/10 01:26 PM
Posts: 147 Milledgeville, (central) Georg...
Bighead440
I too have run the TorkerII, the AirGap and M1 single plane on a couple of small blocks, to see which one was better. The first was my 3100lb Demon with a 360, KB107 pistons, MP .528" mechanical cam (w/1.6 rockers-.563") and unported 2.02x1.60" "J" heads. The car ran the exact same MPH (109)but was overall quicker (60ft much better with RPM AG) comparing the RPM AG to the TorkerII. On the street the RPM was hands-down better at part throttle, which made me like it best. Then on a 416 with 10.5:1 compression, Ultradyne solid .590" cam and OOTB Eddy heads (Comp 985 spring, 10deg lock upgrade) in the same car with the M1 SP as the baseline, I STILL got a 60ft boost but the same MPH (118)with the switch to the AG RPM. I attribute this to the low rpm nature of the 4" stroke motor with mild flowing heads. I think the M1 SP might MPH better on a 3.79" stroke motor, or with Indybrocks or Large Port Commandos on the same 416" shortblock. Now I am putting a 13:1 416 in the same car with a fully ported set of Indybrocks, a Lunati solid roller and a Super Victor , wonder if the RPM AG would pick it up as well..? RB
