Re: Running 2 Air compressors to paint Gun
[Re: Kern Dog]
#690861
05/07/10 08:04 AM
05/07/10 08:04 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
A smart paint supply store manager told me, and I have found this to be true, is that what you need is a compressor that is capable of maintaining a minimum of 20 PSI at the gun for 2 1/2 minutes. She, (Thats right... A Woman!) said that this represents the average amount of time it takes for a full sweep... Meaning a full pass on every panel of the car. If your 5 Horse compressor works properly and has an upper PSI limit of at least 100 lbs, you should do fine. You can test yourself, as long as you have a pressure regulator on the gun. Run it wide open for 3 minutes and if you stay at or above 20 PSI...Goodbye MAACO !
So your gonna wait for the compressor to recover after each Panel.... Good Luck with that... Can you say dry blend...
[Re: 1_WILD_RT]
#690862
05/07/10 08:08 AM
05/07/10 08:08 AM
Challenger 1
Cincinnati, Ohio
Yea after rereading the OP post, I don't think 2 20 gal compressors are gonna do the job. I set my gun at around 40 psi so I don't know what good 20 psi would do. My 5hp 2 stage 80 gal compressor runs almost non stop when I paint.
[Re: Challenger 1]
#690864
05/14/10 08:54 PM
05/14/10 08:54 PM
Posts: 5,912 Athens, Greece
Pyper70
Athens, Greece
My HVLP Devilbiss only need 18-22lbs at the gun to operate normally. I assume you are using a siphon feed for the 40lbs?
Other thing you can do is run both air compressors with lines to the car. Paint one body panel with one compressor, when the volume runs down, switch compressors. You will always have one with air ready to go and there wont be paint drying on your car between panels
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Kern Dog]
#690865
05/14/10 09:13 PM
05/14/10 09:13 PM
Posts: 21,847 Kirkland, Washington
Pacnorthcuda
With your 20psi I will assume your talking about HVLP, cuz conventional usually requires 40-50psi. OK. The 2.5 minutes per panel might be fine if your ONLY doing panels, bit if you're spraying a whole car that not how it works--you don't/can't start/stop at each panel. You have maintain a wet-edge, which requires MUCH more time than 2.5 minutes.
