I have a '73 Charger, ps, auto on column with a shot rag joint 3 inches of play in steering wheel(I can move the coupler side to side by hand 1/2 inch) and I have a nos replacement. After unbolting the column from under the dash and floor and disconnecting the column harness and shift linkage, what is next? Is there a pin near the steering box that has to come out or just pull the column? I can see a little of the shaft spline between the coupler and steering box. If there is a pin, do I tap it out from top or bottom side? I also have the kit(seal, shoes, spring, pins, cap) to fix the smaller upper coupling that the cap popped off and is bone dry.
