Low ratio gearset
#689793
05/05/10 09:04 PM
05/05/10 09:04 PM
Posts: 1,200 UK
602heavy
UK
How much have you guys picked up using the low ratio gear set? , 4400lb 68 charger , best yet has been a 10.01 @ 139.6 mph , sheered the splines off the front gear set on saturday @ Santa Pod , so have decided to go for steel gear set , are these much noisier than the alu? , the one going in is a straight cut set. Been short shifting using the three on the tree (5600rpm) so also gonna go reverse pattern while this is out the motor , just thinking this heavy ole elephant might pick up with the above modification , should be able to shift around 7k with the RPVB , best 60ft has been around 1.5 with 4.10 rear gear , 29" tyre , any thoughts? TIA
Re: Low ratio gearset
[Re: 602heavy]
#689796
05/06/10 11:30 AM
05/06/10 11:30 AM
Posts: 1,880 USA
Ron Silva
USA
Once you start making big HP, the low gearset can work against you. With your weight and that MPH, I will say you are making big HP.
If you are dead hooking it might help though. Anything else and your traction problems will get worse. Or maybe you will have trouble with too much of a wheelstand. Less starting line ratio is more consistent/reliable 60 foot and more controllable wheelie.
I took the low gearset out of my Demon and I liked it better. Did'nt really slow the car down much if at all.
SRT DEMON ONE SEAT
[Re: 602heavy]
#689798
05/06/10 01:35 PM
05/06/10 01:35 PM
Posts: 2,933 A shed in England
Tig
A shed in England
Cope and Southlands both recommended not to do it when I broke my front planetary. I do have traction problems though.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: 602heavy]
#689800
05/06/10 02:10 PM
05/06/10 02:10 PM
Tig
A shed in England
[Re: fatman]
#689802
05/06/10 04:21 PM
05/06/10 04:21 PM
Tig
A shed in England
