LA Small Block Water Pump Bolt Lengths? #68978
06/06/08 10:42 PM
06/06/08 10:42 PM
Milwaukee, WI
In_The_Pink Offline OP
Milwaukee, WI
What are the correct bolt lengths for the seven water pump bolts on an LA engine with alternator and P/S pump brackets, if that matters.
Are all of the bolts supposed to have flat washers under the heads?
Re: LA Small Block Water Pump Bolt Lengths? [Re: In_The_Pink] #68979
06/07/08 02:13 AM
06/07/08 02:13 AM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Re: LA Small Block Water Pump Bolt Lengths? [Re: 68Fastback] #68980
06/07/08 08:00 AM
06/07/08 08:00 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I run lock washers under mine.
Re: LA Small Block Water Pump Bolt Lengths? [Re: 68Fastback] #68981
06/07/08 05:57 PM
06/07/08 05:57 PM
Milwaukee, WI
Milwaukee, WI
http://www.moparts.org/Tech/Archive/smallblock/2.html
I saw that, but some of the bolt lengths don't seem correct.
Re: LA Small Block Water Pump Bolt Lengths? [Re: In_The_Pink] #68982
06/07/08 09:29 PM
06/07/08 09:29 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Is this a '69 and earlier or a later model because the water pumps are not the same? I don't think the lengths look completely correct myself, at least not for the earlier small blocks. If you are asking about the earlier SBs I just painted my assembly for the new engine. I can get it out of storage and check the lengths if you want?
