70 hemi engine harness pic #689077
05/05/10 06:40 AM
05/05/10 06:40 AM
indiana
mopar mike Offline OP
indiana
i am trying to get the engine harness on my 70 cuda. not showing very good pics in the fsm. anyone have some pics of the engine out of the vehicle with the engine harness in the correct place? or in vehicle if you can see it clearly? also is the dist hold down left plated and not painted? thanks moparts
Re: 70 hemi engine harness pic [Re: mopar mike] #689078
05/05/10 10:15 AM
05/05/10 10:15 AM
indiana
indiana
Re: 70 hemi engine harness pic [Re: mopar mike] #689079
05/05/10 11:12 AM
05/05/10 11:12 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
the dist hold down is plated - clear cad.
Re: 70 hemi engine harness pic [Re: Morty426] #689080
05/05/10 12:10 PM
05/05/10 12:10 PM
indiana
indiana
thanks, any pics of the engine wiring harness??
Re: 70 hemi engine harness pic [Re: mopar mike] #689081
05/06/10 06:47 AM
05/06/10 06:47 AM
indiana
indiana
no one has any pics of there engine in or out of there cars???
Re: 70 hemi engine harness pic [Re: mopar mike] #689082
05/06/10 11:50 AM
05/06/10 11:50 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Manual or automatic?
Re: 70 hemi engine harness pic [Re: Snoopy] #689083
05/06/10 12:42 PM
05/06/10 12:42 PM
indiana
indiana
manuel, with power steering, thanks
Re: 70 hemi engine harness pic [Re: mopar mike] #689084
05/06/10 12:54 PM
05/06/10 12:54 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Mike,
What part of the harness? The engine harness is two pieces. Both are pretty simple. The front half - start at the temp sender, the harness is held in the looms on the passenger side valve cover. The back half - start at the oil pressure switch and it's held in the looms on the fire wall.
Re: 70 hemi engine harness pic [Re: Morty426] #689085
05/06/10 02:46 PM
05/06/10 02:46 PM
indiana
indiana
the front harness. it looks really tight at all connections? i have no pics to tell if i am routing it right. it was a 383 car when i started and cloning the hemi. just wanted to try to get as much together as possible to not have to lean over the fenders anymore than possible.
Re: 70 hemi engine harness pic [Re: mopar mike] #689086
05/06/10 02:59 PM
05/06/10 02:59 PM
Snoopy Offline
Snoopy  Offline
Here are a couple of pictures of Dave Waldens (ECS) Hemicuda.
Re: 70 hemi engine harness pic [Re: Snoopy] #689087
05/06/10 03:04 PM
05/06/10 03:04 PM
Snoopy Offline
Snoopy  Offline
2
Re: 70 hemi engine harness pic [Re: Snoopy] #689088
05/06/10 04:32 PM
05/06/10 04:32 PM
Snoopy Offline
Snoopy  Offline
3
Re: 70 hemi engine harness pic [Re: Snoopy] #689089
05/06/10 04:33 PM
05/06/10 04:33 PM
Snoopy Offline
Snoopy  Offline
Re: 70 hemi engine harness pic [Re: Snoopy] #689090
05/07/10 07:05 AM
05/07/10 07:05 AM
indiana
indiana
can't see it real well, but does the harness run down the outside of the valve cover then?
Re: 70 hemi engine harness pic [Re: mopar mike] #689091
05/07/10 07:16 AM
05/07/10 07:16 AM
florida
P
PJM Offline
PJM  Offline
P
florida
Yes it runs on the outside.
Re: 70 hemi engine harness pic [Re: mopar mike] #689092
05/07/10 07:19 AM
05/07/10 07:19 AM
Snoopy Offline
Snoopy  Offline
Click on the attachment for a larger view.
Re: 70 hemi engine harness pic [Re: Snoopy] #689093
05/07/10 04:06 PM
05/07/10 04:06 PM
California
mickm Offline
mickm  Offline
California
i thought the PCV was on the passenger side, and the breather on the driver side.
is that not correct?
Re: 70 hemi engine harness pic [Re: mickm] #689094
05/07/10 05:07 PM
05/07/10 05:07 PM
Snoopy Offline
Snoopy  Offline
On a 70-71 Hemi the PCV valve is on the drivers side, just like in the photo.
Re: 70 hemi engine harness pic [Re: Snoopy] #689095
05/07/10 05:26 PM
05/07/10 05:26 PM
California
mickm Offline
mickm  Offline
California
LSNED, (learn something new every day!)
thanks!
Re: 70 hemi engine harness pic [Re: mickm] #689096
05/10/10 10:57 AM
05/10/10 10:57 AM
indiana
indiana
after close examination on all the pics, i have not got the right harness! it is packaged 70-71 hemi ebody! from year one, but it looks like a small block harness. i knew i wasn't crazy, but never restored a hemi and wasn't sure if it was right? thanks for all the help, i have got to get it straightened out with year one!! thanks moparts
