Post deleted by Defbob
[Re: TheOtherDodge]
#688840
05/04/10 11:05 PM
05/04/10 11:05 PM
Re: Clever ways to mount trans brake button?
[Re: TheOtherDodge]
#688842
05/05/10 11:00 AM
05/05/10 11:00 AM
Posts: 577 Arkansas
Adrielp
Arkansas
I know this option has not been made popular, but we mounted our transbrake button right beside the shifter. We got tired of the cord rapping around the steering wheel. Reaction times are still consistent as well.
Adriel Paradise Substation Design Engineer III
[Re: Adrielp]
#688843
05/05/10 12:16 PM
05/05/10 12:16 PM
Posts: 235 Tucson AZ.
RADAMX
Tucson AZ.
I use a throttle position switch to release my brake and I set it with a relay loop activated by a toggle with start . I set it by pushing the start on the toggle and pull up on the brake, part throttle . when I mat the throttle away it goes. leaves my hands free to drive.
[Re: TheOtherDodge]
#688845
05/05/10 12:34 PM
05/05/10 12:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Not very clever but its done well for me... heres a couple of pics... you will notice that the button is below the steering wheel surface just so I cant bump it while in low gear
[Re: MR_P_BODY]
#688847
05/05/10 12:38 PM
05/05/10 12:38 PM
#688848
05/05/10 01:02 PM
05/05/10 01:02 PM
Posts: 12,339 somwhere
smokinwoody
somwhere
trying something different this year
just squeeze and you go http://shootthelite.com/products/products.htm
watched all the vids they have on each of their products...I think thats the way to go for TB's and perhaps a few other installations...
[Re: smokinwoody]
#688849
05/05/10 01:08 PM
05/05/10 01:08 PM
MR_P_BODY
I can say that wouldnt be for me... I dont like the idea of pulling the trigger so I would have to be barely touching it and would be afraid of firing it JMO
[Re: Dabee]
#688851
05/05/10 01:33 PM
05/05/10 01:33 PM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
I don't like having a cord wrap around the steering wheel, so I mounted my microswitch button to my Cheetah shifter. Since I (usually) use a Co2 shifter it is completely out of my way once I release it.
When I bottom bulb race I use a plunger type button that requires more force than I want to apply to the shifter. The clever way would be to weld a bracket to the floor for it to mount to. The crude way (my way) is to mount it to the steering wheel, but I have a sturdy electrical connector in the cable. After a pass while slowing in the shut down area, I just unplug the cord. Then when I turn off there is no cord to wrap around the wheel.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
[Re: TheOtherDodge]
#688854
05/05/10 06:48 PM
05/05/10 06:48 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
ill mention this... i like to use either a slide my finger sideways off the button to let it snap..to activate or use a snatching motion pulling finger/hand away from button with bicept muscle. snatching your hand towards your face..is a proven fast reaction... lifting your finger with finger/hand muscles is lazy IMHO. so is lifting just your finger...with your rist muscles... ive seen alot of switches mounted where your rist has to be bent to access it.. this just doesnt seem fast or consistant enough for me.. currently mine is on the dash just to the right of where your hand might reach to turn the ignition key.. i like this...although i have contemplated making a braket to make it about 6" off the dash.. (6" closer to my body) to activate it i just snatch my hand off...then set it down on the shifter ..to prepair for 2nd gear.. the same muscles you would use to put food towards your mouth... fwiw...thats my logic....? the steering wheel location is decent ..but like everyone else i dont want to mess with the cord. cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: cheapstreetdustr]
#688855
05/05/10 07:04 PM
05/05/10 07:04 PM
[Re: TheOtherDodge]
#688858
05/05/10 09:03 PM
05/05/10 09:03 PM
Posts: 8,859 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
that would be impossible as if it was hooked to the horn switch and was on wrong side (horn side) you could tell tell when you was backing up (bump to netural and het the t brack and it will back up) dont know many racers that actually put the shifter into reverse if they have a trans brake
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
