Re: Dash Parts
[Re: Hemiruss]
#688739
05/05/10 07:53 AM
05/05/10 07:53 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
The headlamp delay and switch will be very hard to find new. The floor dimmer switch can be picked up and are readily available. I'm almost certain there is someone who's rebuilding the headlamp switches. I'll see if I can find it. If not, someone else may post........
I wouldn't worry too much on the delay...
Troy
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Dash Parts
[Re: Hemiruss]
#688741
05/05/10 12:14 PM
05/05/10 12:14 PM
Posts: 601 Mass
charge70
Mass
Russ,there is a member on this board he goes by the name devinism He rebuilds dash dimmers and I believe switches.Give him a shout he can probably help you out.In case you want new stuff,the h/lamp delay relay is part# 2947394,these pop-up on ebay from time to time,h/lamp sw.is# 3004092 dash dimmer is 2809047,this has many supersceded #'s and they will all fit and work.Good luck with your car. John.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Dash Parts
[Re: charge70]
#688743
05/05/10 02:08 PM
05/05/10 02:08 PM
340dart4spd
Parts Problem
Parts Problem
Dig out your wallet..
