Metal valve stems??
#688030
05/04/10 11:21 AM
05/04/10 11:21 AM
Posts: 1,898 Milwaukee WI
R_Blaha
Milwaukee WI
I bought a set of bogarts used and they have rubber valve stems. My question is I thought to run at a NHRA track you needed the metal valve stems, is this still true? I know these wheels went 10.69 @ 133mph with no problems but I don't know if it was a IHRA track or NHRA. I plan on running at a NHRA track. Thanks
LOOKING FOR THE 68 GTS IN THE AVATAR SPOT 1969 Dodge Superbee post coupe 383 1969 Dodge Superbee hardtop 472 hemi 1989 Mustang GT 1993 mustang lx 5.0 2004 screaming yellow cobra 2013 CVO Roadglide
Re: Metal valve stems??
[Re: R_Blaha]
#688035
05/04/10 05:23 PM
05/04/10 05:23 PM
Posts: 2,112 Byron, NY
W.I.N. Racing
Byron, NY
Metal screw in valve stems, front and rear quicker than 12.00sec. dem's the rules
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#688036
05/04/10 07:03 PM
05/04/10 07:03 PM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
/w what he said! Metal stems needed at 11.99 2010 NHRA 5:1 TIRES Tires will be visually checked for condition, pressure, etc. and must be considered free of defects by the technical inspector prior to any run. All street tires must have a minimum of 1/16-inch tread depth. Temporary spares, space saver spares, farm implement or trailer tires prohibited. Metal, screw-in valve stems mandatory in tubeless tires, front and rear, on vehicles running 11.99 or quicker.
[Re: ProStDodge]
#688037
05/04/10 09:40 PM
05/04/10 09:40 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Okay, real stupid question here... "Metal, screw-in valve stems" I've seen plenty of metal stems, but they all seemed to be the nut and rubber washer style. They don't "screw-in" to the wheel. Am I mis-reading?
[Re: RodStRace]
#688040
05/05/10 03:37 AM
05/05/10 03:37 AM
ProStDodge
RodStRace - no such thing as a stupid question!
The valve stem you are referring to are the proper ones - I suppose it would be more correct to specify "bolt-on" or "screw-on". But in effect they need to have a metal body and mechanical attachment.
The reasoning for the metal valve is to reduce the chances of something breaking the valve stem loose (or dry-rotting off). I remember back in the days of being a tire/battery guy, we used to knock the old rubber ones out with a single whack from the side rather than trying to pull them out. A little side pressure cuts'em right off!
Pro6pakRR - current wording would indicate otherwise.
"Metal, screw-in valve stems mandatory in tubeless tires"
Scott
[Re: pro6pakRR]
#688043
05/05/10 11:29 AM
05/05/10 11:29 AM
ProStDodge
what's it say about tube's?
I found nothing mentioning anything about tubes in all of ET (pro, super pro, sportsman), Stock/Super Stock, S/G, or general regs.
The above quoted 5.1 tire reg was pasted in its entirety from the general regs.
