Glazing high gear clutches on the street?
#687989
05/04/10 10:10 AM
05/04/10 10:10 AM
Posts: 3,336 Summit, NJ
whiplash
Summit, NJ
Just had my trns freshened. 727 behind motor in sig. the trans guy told me that the high gear (3rd) clutches were ok but glazed. He said every high stall converter with a high hp motor on the street glazes the 3rd gear clutches. His reasoning was that the converter is stalling at 3500 rpm and your cruising at 2000, so your always slipping, causing heat and glazing the clutches.
Not wanting to argue with him, I wanted to understand this reasoning more with you guys. I don't necessarily agree with the theory, unless the heat in the fluid around the clutches, not in the pan, gets hotter due to the slipping converter? Could it be that there isn't enough line pressure at low rpms? Does the slipping converter effect line pressure? What do you guys think?
- 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
- 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
- NEW BEST ET - 12.40@110mph...
Re: Glazing high gear clutches on the street?
[Re: whiplash]
#687990
05/04/10 11:25 AM
05/04/10 11:25 AM
Posts: 5,080 organ
maximum entropy
organ
it would be good to put a temp gauge in that thing, but, the direct clutch may be slipping, which has nothing to do with your converter. is it an automatic valve body? is your throttle pressure linkage adjusted properly? it could be a line pressure issue, inadequate clutch disc clearance, or possibly a clutch piston seal problem, among others. fwiw, i have a "high horsepower high stall" car that gets driven on the street- a lot!
[Re: Dragula]
#687992
05/04/10 01:21 PM
05/04/10 01:21 PM
whiplash
Summit, NJ
thanks guys, the above post is how I understand the workings of it. So the glazing could be happening from not enough line pressure, or if the 2-3 shift is not instantaneous.
FWIW, the trans is an auto valve body, deep pan, trans temp gauge never goes above 180 (sending unit in pan), has a cooler on it. The shift linkage is set correctly. The trans itself was originally a TCi super street fighter that I recently had rebuilt(not by TCI), so the VB has some mods to it by TCI.
[Re: whiplash]
#687993
05/04/10 01:43 PM
05/04/10 01:43 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
thanks guys, the above post is how I understand the workings of it. So the glazing could be happening from not enough line pressure, or if the 2-3 shift is not instantaneous. {b] Only if you have a huge overlap issue and it has alot of miles on it
FWIW, the trans is an auto valve body, deep pan, trans temp gauge never goes above 180 (sending unit in pan), has a cooler on it. The hottest fluid is coming from the convertor , it's the line at the front of the trans , I'd put the sender for your guage there .
The shift linkage is set correctly. The trans itself was originally a TCi super street fighter that I recently had rebuilt(not by TCI), so the VB has some mods to it by TCI. TCI stands for total [Email]CR@P[/Email] Inc.
[Re: whiplash]
#687995
05/04/10 02:25 PM
05/04/10 02:25 PM
Posts: 30,431 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
Me thimks your trans-guy should go back to school and take ..... Transmissions-101 ! HEAT would contribute-to maybe .5% of glazing of clutches. SLIPPAGE or a severe overlap of the 2/3 shift is the remainder 99.5% of potential probs. Slippage ....due to low line pressure OR worn sealing rings OR leaking rubber seals and/or excessive clutch clearances.
[Re: whiplash]
#687996
05/04/10 02:35 PM
05/04/10 02:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm not a trans guy but its not due to the conv... when you are street driving and are taking off with just part throttle your engine isnt making the torque to stall it at the higher stall point so its acting more like a normal conv(it takes torque to have them stall at thew higher point)... might just be the lack of line pressure
[Re: whiplash]
#687998
05/04/10 07:55 PM
05/04/10 07:55 PM
Posts: 2,177 ill
dennismopar73
ill
never liked tci junk i have hade several buddy had acomplete trans /convert from them bolt in with fluid burned up in less than 300 miles and jegs didnt warrenty it because it went into a 'race car' but i agree with the above line pressure, or miss adj bands
[Re: turbobitt]
#688000
05/05/10 01:39 PM
05/05/10 01:39 PM
whiplash
Summit, NJ
ok thanks Doc, that's what I was thinking. 2-3 shift overlap due to less than adequate line pressure for whatever reason.
Yes it has the deep pan with the deep pan pickup. It started as a TCI trans, but I had it rebuilt with "better" parts (not getting into whta was changed cause it will cause a pi$$ing match and was not part of the problem).
