Removing door VIN sticker to reuse. #687961
05/04/10 09:30 AM
05/04/10 09:30 AM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Hi, I just bought a replacement door and now need to remove the VIN label from the original and re-install on the replacement.
Re: Removing door VIN sticker to reuse. [Re: cudabitten] #687962
05/04/10 09:52 AM
05/04/10 09:52 AM
uk
TiMopar Offline
TiMopar  Offline
uk
That can't be done, it's designed to destroy itself if you peel it off. However you can get new repro ones with your vin printed.
Re: Removing door VIN sticker to reuse. [Re: cudabitten] #687963
05/04/10 09:55 AM
05/04/10 09:55 AM
Highland, Michigan
1972Rallye Offline
1972Rallye  Offline
Highland, Michigan
Not really likely. Somebody may have a trick to do it, but those decals were made to not come off in tact. You'd probably be better off contacting ECS for a replacement sticker.
Re: Removing door VIN sticker to reuse. [Re: 1972Rallye] #687964
05/04/10 10:42 AM
05/04/10 10:42 AM
eastern, pa.
eastern, pa.
Yes, that what I think as well. I hate loosing the original but the original door was so badly smashed, I had no choice. Thanks for the reply.
Re: Removing door VIN sticker to reuse. [Re: cudabitten] #687965
05/04/10 10:56 AM
05/04/10 10:56 AM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
that stinks
Re: Removing door VIN sticker to reuse. [Re: joelson6] #687966
05/04/10 11:10 AM
05/04/10 11:10 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Contact Dave at ECS, he is an expert at removing decals intact. You won't be able to reuse your old one, but you will be able to save it for your historical record. Make sure you take a few closeup pictures of your decal before trying to remove it. Dave can use the pictures or a scanned image to accurately reproduce a replacement.
Re: Removing door VIN sticker to reuse. [Re: Snoopy] #687967
05/04/10 11:11 AM
05/04/10 11:11 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
just cut the metal around it and save it... or re-skin the door dan
Re: Removing door VIN sticker to reuse. [Re: ph23vo] #687968
05/04/10 12:27 PM
05/04/10 12:27 PM
eastern, pa.
eastern, pa.
Thanks, I called there after 72ralley mentioned thier name. The guy I talked to gave me a price of $60 plus 6 for shipping, which is less than the site advertises. I will call back and ask for Dave, it is importmant to me to retain the original as good as possible. Thanks,again.
Re: Removing door VIN sticker to reuse. [Re: cudabitten] #687969
05/04/10 03:31 PM
05/04/10 03:31 PM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
I was able to remove mine in mostly one piece, I just wanted to have the original for documentation of the car. Just used a razor blade and slowly cut away the paint from below the sticker. Tedious yes, but effective.
Re: Removing door VIN sticker to reuse. [Re: Quikshft] #687970
05/04/10 04:04 PM
05/04/10 04:04 PM
Midwest
Lee1 Offline
Lee1  Offline
Midwest
You should be able to remove it with a sharp blade and a heat gun. I would start with low heat.
Re: Removing door VIN sticker to reuse. [Re: cudabitten] #687971
05/04/10 05:51 PM
05/04/10 05:51 PM
Snoopy Offline
Snoopy  Offline
The original had a built in anti-tamper device to prevent it's removal and re-installation on another car. The word "VOID" will appear when you try to peel it off.
Re: Removing door VIN sticker to reuse. [Re: cudabitten] #687972
05/04/10 11:36 PM
05/04/10 11:36 PM
Lost in the 70's
440gtx6 Offline
440gtx6  Offline
Lost in the 70's
Piece of cake. Just watch the original Gone in 60 Seconds, they show you how.
69 EF8 GTX 440 auto
72 EB5 RR/GTX 440 auto
70 EW1 GTX 440-6 4 spd
70 EF8 Satellite 318 auto (452 coming soon)
70 FK5 Satellite 318 auto
71 FC7 Cuda 340 4 spd
Re: Removing door VIN sticker to reuse. [Re: 440gtx6] #687973
05/05/10 09:42 AM
05/05/10 09:42 AM
SE Pa.
LimeliteAero Offline
SE Pa.
I cant tell you how to save it but I can describe in detail how to destroy one...........
