Hughes rocker shaft hold down set questio. #687937
05/04/10 09:20 AM
05/04/10 09:20 AM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Does anyone use this kit with the springs that hold the rockers apart. I've got alloy spacers between mine but they are too wide, so i'm thinking of using the original springs, either that or i will have to have some more spacers machined up.
Mick
Re: Hughes rocker shaft hold down set questio. [Re: deaks] #687938
05/04/10 01:45 PM
05/04/10 01:45 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I like the spacers better than the springs , just have the spacers machined down , you want a max of .010 clearance between the rockers and the spacer to the holdown .
Re: Hughes rocker shaft hold down set questio. [Re: JohnRR] #687939
05/04/10 02:32 PM
05/04/10 02:32 PM
.010 may work good on ductile iron or stainless rockers, Harland Sharp and T&D want .015 minimum cold I like more than that just to be safe on aluminum rockers
Re: Hughes rocker shaft hold down set questio. [Re: Cab_Burge] #687940
05/04/10 03:18 PM
05/04/10 03:18 PM
JohnRR Offline
JohnRR  Offline
Good point Cab , he doesn't mention what rockers he is running
Re: Hughes rocker shaft hold down set questio. [Re: JohnRR] #687941
05/04/10 05:35 PM
05/04/10 05:35 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Ductile, the hold downs knock the rockers way off centre. I have used the studs with my stock hold downs and washers.
Mick
Re: Hughes rocker shaft hold down set questio. [Re: deaks] #687942
05/04/10 06:06 PM
05/04/10 06:06 PM
organ
maximum entropy Offline
organ
if they are like harland's, no shimming is necessary (other than the hardened spacers). the harland hold downs have enough play in the bolt holes to allow moving them side to side slightly. i pull the shaft down just snugging the bolts, and back off the valve adjusters all the way (keep the ball protruding so the pushrod doesn't contact the rocker). torque the center hold down. turn the engine until a pair of rockers next to the center hold down are both loose, insert your feeler gauge, and torque the next hold down out to "set" the side clearance. turn the engine for the next pair and work your way out. i suspect that will work for the hughes rockers as well.
Re: Hughes rocker shaft hold down set questio. [Re: maximum entropy] #687943
05/04/10 06:29 PM
05/04/10 06:29 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
The rocker tip is only half on the valve
Re: Hughes rocker shaft hold down set questio. [Re: deaks] #687944
05/04/10 06:48 PM
05/04/10 06:48 PM
organ
organ
that will definitely require monkeying with some shims.
Re: Hughes rocker shaft hold down set questio. [Re: deaks] #687945
05/04/10 07:12 PM
05/04/10 07:12 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i recently set up a pair of eheads with crane ductile rockers using hughes spacers and steel shaft hold downs. i had to machine the ends of the hold downs off a little bit to get the rocker to tip alignment centered. it would have been even more work to use the isky rockers with this setup. not that there's anything "wrong" with any of the parts imho it's just one of those "cut to fit" deals we so often run into with performance parts especially mopar stuff
Re: Hughes rocker shaft hold down set questio. [Re: deaks] #687946
05/04/10 08:53 PM
05/04/10 08:53 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Iskys? They are made to wide & need to be narrowed to work properly.... I set up a clamp for my buddies lathe that allowed me to cut down a set quick & easy...I intentionally cut the rocckers a little to thin so I could shim them just how I wanted them...
Re: Hughes rocker shaft hold down set questio. [Re: 1_WILD_RT] #687947
05/04/10 08:58 PM
05/04/10 08:58 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I had to get my Iskys trimmed down quite a bit by Gary at RAS when I used the Hugh's holddowns.
Gus
64 Plymouth Savoy
Dana 60
Re: Hughes rocker shaft hold down set questio. [Re: fourgearsavoy] #687948
05/04/10 09:03 PM
05/04/10 09:03 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Gus
I've got a couple sets I want to send in & have bushed but I figure anything I can do myself that is done correctly is one more thing I don't need to pay someone else for...
Re: Hughes rocker shaft hold down set questio. [Re: 1_WILD_RT] #687949
05/05/10 05:59 PM
05/05/10 05:59 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I will get them machined later, i've a lot to do and hope to have the car out by the end of the month.
Thanks for the ideas though.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Hughes rocker shaft hold down set questio. [Re: deaks] #687950
05/06/10 12:24 PM
05/06/10 12:24 PM
JohnRR Offline
JohnRR  Offline
Mick
If you have original Isky's the paperwork that comes with them tells to modify the stock hold downs, the Hughes/RAS holdowns are the same width as stock holddowns .
Re: Hughes rocker shaft hold down set questio. [Re: JohnRR] #687951
05/06/10 05:40 PM
05/06/10 05:40 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I think they are the crane ones, they have a flat bladed screwdriver fitting on the adjusters.
They would be closer if they were all the narrower size.
Mick
Re: Hughes rocker shaft hold down set questio. [Re: deaks] #687952
05/06/10 05:45 PM
05/06/10 05:45 PM
tboomer Offline
tboomer  Offline
Mick...The Iskys I just sold to a member here were marked"Isky" right on them...The Cranes we took off were not marked...I used the Hughes kit but had springs instead of the spacers...
Re: Hughes rocker shaft hold down set questio. [Re: deaks] #687953
05/06/10 09:54 PM
05/06/10 09:54 PM
NC
440Jim Offline
440Jim  Offline
NC
Although I like solid spacers shimed/sized for desired clearance between the rockers...
For a mild setup, the springs work just fine.
I run them in my street/strip 440 with stock heads and crane iron rockers, with a MP 0.557" solid lifter cam.
Re: Hughes rocker shaft hold down set questio. [Re: 440Jim] #687954
05/18/10 09:44 PM
05/18/10 09:44 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Boy i am glad i found this post. I have a 440 that i just started mocking up to night. I have a set of Indy EZ heads and a comp solid roller that is 264 @ 0.50 and 634 lift with my crane 1.6 roller rockers.I am also using the hughes rocker hold downs.I am using the spring spacers that came with the rockers. but most of my rockers do not line up with the valve tips now.I know i am going to have to Grind on the hold downs. But would it be better to just have .010-0.020 machined off each side of the hold downs and then just shim the rockers back up to wear they are right now? OK next question i screwed all my rocker shaft hold down studs on my heads by hand.with the spacers on the shaft and with the rocker shaft studs tightened down. it looks like all my studs are going to be to short. the instructions that cam with the kit said they are set right when the top of the stud is even with the top of the nut.well most of mine are not like that. so looks like i am going to have to get longer studs. who else makes rocker shaft hold down studs.OK last question. with my comp solid cam should i swap out the crane spacer springs to solid ones? Thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Hughes rocker shaft hold down set questio. [Re: mopar65] #687955
05/18/10 10:35 PM
05/18/10 10:35 PM
IN
ahy Offline
ahy  Offline
IN
I uaed the method you described with MOPAR aluminum holddowns and comp steel rockers. I got a shallow cut with a mill on the holddowns and used a couple packs of steel shims from Mancini to get everything centered. Works great.
Re: Hughes rocker shaft hold down set questio. [Re: ahy] #687956
05/18/10 11:39 PM
05/18/10 11:39 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
FWIW I used the Hughes hold down set with the comp rockers. We machined the hold downs and used shims to position the Pro Magnum rockers over the valves and to maintain clearence.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
