Went to change the plugs on the ram this weekend 130k (looks like it may have been for the 1st time ever)
Anyway #5 plug turned about 3/4 turn and started to bind tough... turned it back in and moved on.
The other 7 all changed out fine... be it some of the rustiest plugs I've ever pulled.
SO I'm looking for any tricks or thoughts prior to giving it another go.
WD-40 for a week, try it with engine HOT, or Cold...(it was "warm", when I changed them)
Or just leave it
I've read on here b4 of guys snapping them off... I don't want to do that.
Right now it's running, much better too, so I'm even considering just leaving it as is.
7 new is still better than all old... pig gets 11mpg all day every day, doesn't matter how/where you drive it.
Any thoughts?
