74 plymouth valiant 2door same quarters as dart 72-76? #687374
05/03/10 02:25 PM
05/03/10 02:25 PM
el cajon california
deliriumx1 Offline OP
el cajon california
getting some rust repair done on my valiant and need to find full rear quarter panel RH, are 72-76 dart,scamps and valiants the same? also need to find rear window patch panels the vinyl has done a number back there but after hours of googling these a-bodies get no love.
Re: 74 plymouth valiant 2door same quarters as dart 72- [Re: deliriumx1] #687375
05/03/10 05:31 PM
05/03/10 05:31 PM
Canada
demon Offline
demon  Offline
Canada
Yes your Scamp uses the same 1/4's as a Dart. I just installed a set of AMD panels and they were a very good fit with only minor alterations needed
Re: 74 plymouth valiant 2door same quarters as dart 72- [Re: deliriumx1] #687376
05/05/10 10:47 AM
05/05/10 10:47 AM
crlush Offline
crlush  Offline
Only difference is the side marker lights holes, might have the ones for your year, back when I did mine and they only had patch panels you could only get the early side marker light panels, then you would have to weld them up then cut them out for 72 and up markers
