Anyone shoot waterborne paint?
#686500
05/02/10 12:42 PM
05/02/10 12:42 PM
Posts: 11,881 Fallon, Nv
SeventyGTX
Fallon, Nv
I have a choice of painters to shoot a truck I am working on. One is a standard body shop that uses Sikkens, and the other is a guy that has a shop behind his house that uses Sherwin-Williams AVX waterborne. He swears it's the shiznit as far as paint goes. Sherwin-Williams has never had a great reputation with their solvent paints, but not sure on this new stuff. I've been in the collision trade forever, but have not been around any waterborne paints before. The guy that has the AVX system works at the local Navy base as a painter, and that is what they use. The biggest advantage to using the guy with the waterborne is it can get done quickly if I do all the prepping, plus he is much closer. The body shop is a typical body shop where the bread and butter collision stuff gets put ahead of big resto jobs, I know I work there. Are conventional primers compatible with waterborne paints?
Re: Anyone shoot waterborne paint?
[Re: dmerc]
#686508
05/03/10 12:12 AM
05/03/10 12:12 AM
With the advent of waterborne auto paints you will begin to see guys painting cars in there garage with a Graco airless house painting sprayer.
#686509
05/03/10 12:22 AM
05/03/10 12:22 AM
Posts: 403 NE Ohio
71 FJ6 Charger
NE Ohio
Stick with the solvent based. Especially when you are talking Sherwin Williams....I would not use solvent or water from them personally. PPG water-based is the best out there right now anyway.But stay with solvent based. ![](/ubbthreads/images/graemlins/Twocents.gif)
'71 383HP FJ6 Charger SE
[Re: Kern Dog]
#686511
05/03/10 08:18 AM
05/03/10 08:18 AM
Posts: 4,924 new berlin wisconsin
Mr T2U
i am a pro painter with 30 years experience with PPG products. i have only went to school to learn about waterborne paint. the dealer where i work at won't switch over to water based base coat until we move into our new shop that is in the planning stages. a few things i learned in school. water based paint actually drys as fast than solvent based paint with the proper equipment is used. water base paint is VERY thin so you must prep your primer to 600 grit or finer. it has very good adhesion so flaking shouldn't be a problem. you should use a water based pre-cleaner for best results. water based paint is very corrosive so you can't paint over any bare metal spots, so using a sealer before painting is recommended. also you should use a gun made for water based paint. you can't wet sand it. if you get big chunks of dirt in the base you must wipe off the paint and start over on the panel. you spray solvent based clear coat on top of the base coat. things i have heard from other painters is it requires some getting used to. the color match is very good with the newer paints. it blends much easier than solvent based paint. gun clean up is more complicated than with solvent paint. after everything is over you will get a nicer looking paint job with the water based paint a than solvent based job due to less dye back.
perception is 90% of reality
