Altenator mounts with a motor plate #686404
05/02/10 10:58 AM
05/02/10 10:58 AM
Fredericton NB Canada
471b1dart Offline OP
I need some Ideas on where and how to mount an alt on my tube chassis car with a motor plate and msd crank trigger, would like to see some pictures of how you mounted it and the pulleys you used. does anyone make a small alt?? Im kinda limited for space. Thanks
Re: Altenator mounts with a motor plate [Re: 471b1dart] #686405
05/02/10 11:06 AM
05/02/10 11:06 AM
AndyF Online content
AndyF  Online Content
This is the AR207 kit that I make. It is designed for a Mopar K frame but it should also fit in a tube chassis car. The DMI kit might also work, just depends on the shape of your motor plate.
Post deleted by Defbob [Re: AndyF] #686406
05/02/10 11:31 AM
05/02/10 11:31 AM
Re: Altenator mounts with a motor plate #686407
05/02/10 12:52 PM
05/02/10 12:52 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Built my own
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Altenator mounts with a motor plate #686408
05/06/10 10:43 PM
05/06/10 10:43 PM
Thanks for the pictures , who sells the DMI kit , that looks like I can make it work where it has the crank trigger pickup bracket as part of the kit.
Post deleted by Defbob [Re: 471b1dart] #686409
05/06/10 11:13 PM
05/06/10 11:13 PM
Re: Altenator mounts with a motor plate #686410
05/06/10 11:48 PM
05/06/10 11:48 PM
ky
68roadrunner Offline
ky
on my dragster.
Re: Altenator mounts with a motor plate [Re: 68roadrunner] #686411
05/07/10 05:43 AM
05/07/10 05:43 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Re: Altenator mounts with a motor plate #686412
05/08/10 08:12 PM
05/08/10 08:12 PM
Hemifred, what is the brand of the alt, you are using with the DMI kit? It looksas if it might slove my problems . Thanks for the replies and the pictures
Re: Altenator mounts with a motor plate [Re: 471b1dart] #686413
05/08/10 08:35 PM
05/08/10 08:35 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
that alternator is from east coast electric, it's a denso mini. they come in many different flavors and you can pick them up cheaper if you shop around. they're often used on industrial engines like small tractors etc.
Re: Altenator mounts with a motor plate [Re: Dragula] #686414
05/08/10 08:44 PM
05/08/10 08:44 PM
Q
Quicktree Offline
Quicktree  Offline
Q
dragula you stole my idea
Re: Altenator mounts with a motor plate [Re: jamesc] #686415
05/08/10 10:37 PM
05/08/10 10:37 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Someone told me that Kabota uses them on there tractors but I didn't check it out yet.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Altenator mounts with a motor plate [Re: pittsburghracer] #686416
05/09/10 09:25 AM
05/09/10 09:25 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Yes they do. That is what the one I bought was listed for but it is not 1 wire when used on tractor. My alternator shop converted it when it came in. At least that is what he told me.
