Holly 4412 #686342
05/02/10 09:23 AM
05/02/10 09:23 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Where can I get a cheap used base plate for a holly 500 2bbl carb ? Model number 12 4412
shop dummy dropped it and one corner broke off It's for a small pulling tractor and is needed like yesterday
Thanks to all in advance
Thanks Moparts
Re: Holly 4412 [Re: terzmo] #686343
05/02/10 10:13 AM
05/02/10 10:13 AM
Sturgis S.D.
tripleblackcuda Offline
Sturgis S.D.
I think those are a factory Ford carb, like vans some cars. You may want to call Speedway motors also.
Re: Holly 4412 [Re: tripleblackcuda] #686344
05/02/10 11:39 AM
05/02/10 11:39 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Actually both Ford and Chevrolet used the 4412.
Shouldn't be hard to find one.The base casting is the same as Chrysler 6pk center,only difference would be throttle shaft,
Re: Holly 4412 [Re: 62maxwgn] #686345
05/02/10 11:45 AM
05/02/10 11:45 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
the throttle holes are smaller on a 6 pack base vs the 4412...looked at it...thanks
Re: Holly 4412 [Re: terzmo] #686346
05/02/10 02:14 PM
05/02/10 02:14 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
They can be welded by a competent welder or go to holley .com and call them most parts are seviced
Re: Holly 4412 [Re: Dodgem] #686347
05/02/10 02:30 PM
05/02/10 02:30 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
I can't weld a customers carb...what would You say if it was done to You...a new base plate is available for a ton and I just need a functional used one
