67 b-body fuel gauge problem #685597
05/01/10 04:46 PM
05/01/10 04:46 PM
wisconsin
chuckpolzin Offline OP
wisconsin
hey all,
I have very limited knowledge on auto repair, however i was going to attempt to fix my malfunctioning fuel gauge.
This thing will occasionally respond and the needle will go up , usually not all the way but even with a full tank, but at least like halfway or so, sometimes the thing doesnt respond at all.
The dash cluster is a little loose because one of the mounting bracket sites is busted off. A few times i was able to jostle the whole cluster and magically the gauge would perk up again.
Any ideas as to where i should start looking for this. I dont have a lift and dont know if you need to drop the tank to check the ground on the sending unit etc.
Is there a ground site on the cluster itself i should look for to see if the cluster is properly grounded???
any ideas on where to start with this gauge would be awesome, thanks.
Re: 67 b-body fuel gauge problem [Re: chuckpolzin] #685598
05/01/10 05:16 PM
05/01/10 05:16 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The screws that hold the cluster to the dash are the grounds. You can run another ground and it would help.
Re: 67 b-body fuel gauge problem [Re: stumpy] #685599
05/01/10 05:48 PM
05/01/10 05:48 PM
wisconsin
wisconsin
any suggestion as to where to attach a ground wire on the cluster and then somewhere to ground on the frame or body or whatever?
thanks for the advice
Re: 67 b-body fuel gauge problem [Re: chuckpolzin] #685600
05/02/10 07:48 AM
05/02/10 07:48 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Anywhere on the dash that is easy to get to and won't get in the way of anything. Even can use a bolt on your steering column under the dash. I believe there already may be some grd. wires there.
