Rear axle question. #685412
05/01/10 02:01 PM
05/01/10 02:01 PM
Poplar Bluff, Missouri
partfiler69 Offline OP
Still Wondering
Still Wondering
My car has a 7 1/4 axle, if i put an 8 1/4 in it, can i use the driveshaft or would i need one that is a different length?
Back from hiatus
Re: Rear axle question. [Re: partfiler69] #685413
05/01/10 02:05 PM
05/01/10 02:05 PM
PA
U
unclemike Offline
unclemike  Offline
U
PA
If you can't get the drive shaft that came with the 8 1/4, assuming it's out of the same make, model and body style, you will have to shorten yours.
I was going to go that route until I cam across an 8 3/4 cheap.
Re: Rear axle question. [Re: partfiler69] #685414
05/01/10 08:32 PM
05/01/10 08:32 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
shorten 1.6"
Re: Rear axle question. [Re: 446acuda] #685415
05/02/10 11:38 AM
05/02/10 11:38 AM
BDW Offline
BDW  Offline
Re: Rear axle question. [Re: BDW] #685416
05/02/10 08:20 PM
05/02/10 08:20 PM
Still Wondering
Still Wondering
Thank you for the input. I wasn't real clear on what i was doin, the car i bought didn'thave a driveshaft, and a 7 1/4 axle and my donor car had a driveshaft, but was an 8 1/4 axle, and i was going to see about using the driveshaft now and changing axles later. But i guess i will change axles now. lol
Back from hiatus
