Re: Cometic Issues
[Re: moparniac]
#684996
04/30/10 10:11 PM
04/30/10 10:11 PM
Posts: 74 virginia
tigger1
virginia
I just ordered a set for a stock block and procomp heads. the fit is perfect. I would double check that they sent the gaskets for your application ie call them with your information and see if the correct part number was sent.
Twin turbo 440 72 barracuda
Re: Cometic Issues
[Re: tigger1]
#684997
04/30/10 10:14 PM
04/30/10 10:14 PM
Posts: 6,295 U.S.
moparniac
U.S.
everything else fits/looks fine! Im sure they are the right gaskets. anyine else run into this issue? thx
Mopar Performance
Re: Cometic Issues
[Re: moparniac]
#685000
04/30/10 10:27 PM
04/30/10 10:27 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Mine look like that, no issues. I use ultrablack around the water ports up to the valley on all layers and between the heads and valley pan.
I have never cut the rivets. indy maxx aluminum block and 440-1 heads.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Cometic Issues
[Re: moparniac]
#685003
04/30/10 10:34 PM
04/30/10 10:34 PM
bigtimeauto
Trophy Winner
Trophy Winner
I spray them with copper coat also. just spray them till they turn gold. I only wait till they are tacky. I also retorque my heads the next day.
you have a pic of your whole deck with the gasket on?
Re: Cometic Issues
[Re: bigtimeauto]
#685004
04/30/10 10:36 PM
04/30/10 10:36 PM
Posts: 6,295 U.S.
moparniac
U.S.
no not at the moment..... the rest looks real good on fitment though! they are the 4.500 .040s
Mopar Performance
