545fe trans in Ebody anyone install one? #684762
04/30/10 03:13 PM
04/30/10 03:13 PM
W. Bloomfield, MI
71340vert Offline OP
W. Bloomfield, MI
has anyone installed a 545 fe trans in a challenger and how well did it fit, any difficulties? I'm considering installing one behind a Gen III hemi
Re: 545fe trans in Ebody anyone install one? [Re: 71340vert] #684763
04/30/10 04:08 PM
04/30/10 04:08 PM
Buffalo, MN
hydro Offline
super street
hydro  Offline
super street
Buffalo, MN
The 545 transmission is huge. You would have to remake the crossmember and torsion bar mounts to fit that in a 1st gen Challenger.
Re: 545fe trans in Ebody anyone install one? [Re: hydro] #684764
04/30/10 04:31 PM
04/30/10 04:31 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You'd probably have better luck getting a hemi car transmission to fit. They use a much smaller trans than that 545 truck trans.
Re: 545fe trans in Ebody anyone install one? [Re: 71340vert] #684765
05/01/10 12:06 AM
05/01/10 12:06 AM
Hesston, KS
boden Offline
boden  Offline
Hesston, KS
Its not an E body, but I've mounted one in my duster behind a 5.7 hemi. I had to widen the tunnel by about 5" and fabricate a mounting setup behind the stock one. The 545 is a large trans, but I think the benefits will far outweigh the extra effort in installing it, when I eventually get it on the road. If you are not afraid to do some surgery to the hump and mounts I'd say go for it.
