Why does my horn honk? #683661
04/29/10 02:18 PM
04/29/10 02:18 PM
ar
bobs68 Offline OP
bobs68  Offline OP
ar
Why does my horn honk when i turn the steering wheel. I took the horn button off pulled on the wire pushed the wire it don't do it when i put it back together turn the wheel it honks. It's on a 68 b-body.
Re: Why does my horn honk? [Re: bobs68] #683662
04/29/10 02:26 PM
04/29/10 02:26 PM
minnesota
Kirby Offline
Kirby  Offline
minnesota
somehow, it's grounding itself when you turn the wheel-
Re: Why does my horn honk? [Re: Kirby] #683663
04/29/10 03:09 PM
04/29/10 03:09 PM
Houston, TX
Crunchy_Frog Offline
Houston, TX
Easiest thing to do first is a visual. Remove the turn signal switch harness cover from the steering column. Look for crimped/pinched wire (the black one is for the horn), and cracked or deteriorated insulation. If you don't see anything, disconnect the turn signal switch, connect an ohm meter to pin 4 (the black wire) and ground. Look for a short (0 ohms) (or listen for the beep, depending on what type of meter you has access to) while turning the wheel. That's an easier check than yanking the wheel off again.
Re: Why does my horn honk? [Re: Crunchy_Frog] #683664
04/30/10 08:02 AM
04/30/10 08:02 AM
moparx Offline
moparx  Offline
also, on the turnsignal switch, there is a small column with a roller wheel that touches the brass[copper] ring on the bottom of the wheel. this is the ground for the horn switch. inspect the column base closely for cracks. i have replaced many of these that were cracked, allowing the column to "roll over" during steering wheel movement, causing the roller wheel to ground, in turn causing the horn to blow. good luck with what you find.
Re: Why does my horn honk? [Re: moparx] #683665
04/30/10 01:18 PM
04/30/10 01:18 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
i agree with moparx ,atleast thats what my car did,honked when turning,and then later on when not turning.so im going to change that brass ring under the steering wheel this weekend,the horncontact ground connects to it,and it rides on the peg on the turnsignal switch.are the upper bearing in the steering column in good shape?can you wiggle the st-wheel around some?
Re: Why does my horn honk? [Re: bobs68] #683666
04/30/10 05:22 PM
04/30/10 05:22 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
When I saw that as a topic question, I said 'whoo boy. Here we go...'
