Re: 318 ta 390 stroker build update into 4dr coronet
[Re: dulcich]
#683406
04/29/10 02:53 PM
04/29/10 02:53 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
Is it just me, or does is that number seven piston in the wrong hole? -dulcich
Hard to tell with the glare from the flash but yeah it looks like the exhaust valve relief is on the wrong side.
[Re: TheOtherDodge]
#683410
04/29/10 04:57 PM
04/29/10 04:57 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
What heads are you going to run? The Edelbrock heads are pretty nice for a 500 hp type build.
Also, if anyone else is going to start a 390 build, I have rods and pistons that came out of mine for sale in excellent shape with hardly any use. I needed turbo pistons and super strong rods.
He is running the eddy heads, hughes roller rockers, and a hughes flat hydraulic cam. Everything is going pretty smoothly, and the Hughes stuff is checking out pretty good. The machinist took quite a long time, but I dont blame him its racing season, and all the dirt cars are popping left and right. Its also time for planting and field work for me, so Im busy, but its coming along good.
KAsey
[Re: dulcich]
#683411
04/29/10 05:49 PM
04/29/10 05:49 PM
Posts: 1,064 Tennessee
727builder
Tennessee
Yes It is. Good catch. Someone owe's you a beer!
[Re: 727builder]
#683412
04/29/10 08:53 PM
04/29/10 08:53 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I too think that #7 is in backwards....I dont think thats just the camera. The exhaust is on the inside of that piston.
RIP Monte Smith
[Re: Streetwize]
#683414
05/01/10 11:20 PM
05/01/10 11:20 PM
Moparnut426
Well I knew if I had one off, I had too have 2 wrong. I did, and thans guys for the sharp eyes. Thats what ya get when you build engines during calving season. I put #8 in 7s hole, and #7 in 8s hole. At least I didnt have to take a spirolock out and rotate a piston, that would have been really anoying. Im sure glad Vince posted that picture, but Im sure I would have found it when I checked piston to valve clearance, but this saved me a oil pan gasket, and some more grief. You guys are truely great!! I got the two swapped out, and the heads on it for him, oil pans sealed up, Im just waiting on a push rod set, and a cam key. Kasey
