Re: In tank fuel pump installation for FI
[Re: Barnabas_Kriss]
#682450
04/28/10 06:52 AM
04/28/10 06:52 AM
Posts: 12,419 Taxes & Virus's R-US, NY
Dragula
I have done a couple of them in my hotrods, one of which is an e-body with efi, and yes, you need baffels and a sump for accel and decel, otherwise you starve the pump. Foam in the tank is not an option with efi pumps either. Mine sucked all that crap right thru the filter....My tanks were all custom, and $850 if it includes the pump lines, and filter is a deal if it all good quality stuff. ![](http://i427.photobucket.com/albums/pp357/cudahalr/70HemiCuda/Hemi97818.jpg)
[Re: DJVCuda]
#682458
04/29/10 10:26 AM
04/29/10 10:26 AM
Posts: 387 Almont, MI.
gdemon
Almont, MI.
I used kit from Rock Valley. It also has a baffle.
69 Barracuda
70 Cuda
70 Cuda
70 Cuda Conv.
70 T/A Challenger
70 Sport Fury GT
71 Demon 5.7 Hemi
72 Demon
[Re: gdemon]
#682461
04/29/10 11:57 AM
04/29/10 11:57 AM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
Depending on how crazy you want to get, this is the solution that a bunch of the megasquirt-EFI (read: budget) guys are using, and it's most likely what I'll be using since my tank is plastic: It's effectively a surge tank. A low pressure pump supplies the tank (via the port on the right hand side of the picture) with fuel, filling the tank. The T at the top is an overflow that sends excess fuel back to the tank. From the surge tank, via the port on the bottom, the high volume pump sends fuel to the system. Return from the system (TBI or injector rails) is the second line in the T fitting at the top of the surge tank. It's not the prettiest alternative, and maybe not even viable for a car with the underside of it loaded up with stuff, but this application (and mine also) is a Ramcharger.
[Re: gdemon]
#682462
04/29/10 12:04 PM
04/29/10 12:04 PM
Posts: 990 Norwalk, Ohio
sycboi
Norwalk, Ohio
What was the cost of that retro-fit set-up you're showing? Meaning the weld-in sump and pump unit? I cannot seem to locate it on their site...
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
[Re: gdemon]
#682466
05/07/10 01:33 PM
05/07/10 01:33 PM
Posts: 571 Beaverton, OR, USA
Alikazam
super gas
super gas
Beaverton, OR, USA
Out of curiosity, how does it get fuel into the sump area? It appears to be a cylinder. I assume I can't see but that there are a few holes around the base? Thanks, this kit looks interesting. How tall is it overall to the flat? My van's tank is just over 9" tall, hoping that I might be able to put 1 or 2 things like this into it (2 255 lph walbro in tank pumps for my set up, want a 1000 hp capable fuel system, though probably only going for 500 whp EFI & Slight Turbo setup). Thanks for the info.
