Broke A Main Cap! #682077
04/27/10 08:46 PM
04/27/10 08:46 PM
Oconomowoc, WI.
Cudahlr Offline OP
Cudahlr  Offline OP
Oconomowoc, WI.
I went to change a leaking oil pan gasket today on my barracuda, when I got the pan off I did a inspection of everything and found #2 main cap was cracked in half! Ran great at the track 2 weeks ago and i drove it into the shop, has anyone ever seen this?
My question is can I take another cap off another block that I have, and have a machine shop take measurements off the old broken cap, and machine the new one to fit?
This 360 has been together for 10 years and has 200 plus passes on it and lots of street miles and i have never had a problem, I just don't want to build a new engine right now nor do I have the extra cash to do it.
Any help would be greatly appreciated!!
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
Re: Broke A Main Cap! [Re: Cudahlr] #682078
04/27/10 08:51 PM
04/27/10 08:51 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Well you just might have saved the engine from certain catastrophic engine failure...but the good news stop there...
The caps off another block will cause a bad misalignment and it wouldnt be pretty...If no other damage is there, consider your self very lucky.
I would purchase a set of aftermarket main caps, have it lined bored would be the cheapest..and about the only means to save your current block..
Re: Broke A Main Cap! [Re: Cudahlr] #682079
04/27/10 08:52 PM
04/27/10 08:52 PM
snook Offline
snook  Offline
I'd try it. What have you got to lose? Just do an align bore when you finally do get it out for a refresh.
Re: Broke A Main Cap! [Re: snook] #682080
04/27/10 09:09 PM
04/27/10 09:09 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I'd try it. What have you got to lose? out
Block and crank on a GOOD day. Car (or worse) on a bad day when a rod gets spit out the side of the oil pan and puts oil on the track under the rear tires, thats all.
This is assuming that you don't lock up the engine when you torque the new main.
Brian
Re: Broke A Main Cap! [Re: snook] #682081
04/27/10 09:17 PM
04/27/10 09:17 PM
UK
602heavy Offline
602heavy  Offline
UK
Well , if it were ME , i would bolt that other cap down with some green plastigauge & see what i got , would also check all other caps for fatigue/detonation , but that's just what i would do.
Re: Broke A Main Cap! [Re: Cudahlr] #682082
04/27/10 09:17 PM
04/27/10 09:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Try using some plastagauge with the other cap and see
what you come up with... it still wont tell you if
its in line... but I would check the other cap...
I've done some DUMB things before and got lucky
Re: Broke A Main Cap! [Re: MR_P_BODY] #682083
04/27/10 09:21 PM
04/27/10 09:21 PM
Oconomowoc, WI.
Cudahlr Offline OP
Cudahlr  Offline OP
Oconomowoc, WI.
Any idea why this happened? I didn't over rev or detonate or anything out of the ordinary, maybe just fatigue?
Re: Broke A Main Cap! [Re: MR_P_BODY] #682084
04/27/10 09:21 PM
04/27/10 09:21 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
IMO that's a recipie for disaster. The chances of another cap from another block working are a million to one. Don't do it. Pull it out and freshen it or take some time off. JMHO
Re: Broke A Main Cap! [Re: camastomcat] #682085
04/27/10 09:30 PM
04/27/10 09:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I understand your opinion but I sure would look at
the other cap before I gave up.... it sure doesnt hurt
to look
As to why it broke.... unknown without looking at the
other caps(which I would do anyways)
Re: Broke A Main Cap! [Re: Cudahlr] #682086
04/27/10 09:34 PM
04/27/10 09:34 PM
What year is the block and how long has it been a race engine Stuff wears out and breaks See if you can get a set of the Mopar ductile iron replacement caps for your motor, that or a set of steel caps either way it will(probally) need a align hone, make sure and have the crankshaft checked for cracks and straightness before reusing it
Re: Broke A Main Cap! [Re: Cab_Burge] #682087
04/27/10 09:38 PM
04/27/10 09:38 PM
ill
dennismopar73 Offline
ill
yep take her down
check everything
replace with billet
put a gurdle on it
stud it!
Re: Broke A Main Cap! [Re: Cudahlr] #682088
04/27/10 09:45 PM
04/27/10 09:45 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
More than likely, the main cap got a little stretch in one of the cap bolts and it allowed the crank to flex just enough to break it.
Only rite way to fix it.... New caps and linebore..
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Broke A Main Cap! [Re: MR_P_BODY] #682089
04/27/10 09:52 PM
04/27/10 09:52 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
to look
Every time I have changed or replaced main caps, the block need to be aline honed. What do you think the chances are of "looking" at it and knowing whether it is square? And plasti-gauge?
Re: Broke A Main Cap! [Re: MR_P_BODY] #682090
04/27/10 09:56 PM
04/27/10 09:56 PM
Oconomowoc, WI.
Cudahlr Offline OP
Cudahlr  Offline OP
Oconomowoc, WI.
First I would take both caps to my local engine builder and see if he can machine it to match the old one.
Re: Broke A Main Cap! [Re: camastomcat] #682091
04/27/10 09:59 PM
04/27/10 09:59 PM
UK
602heavy Offline
602heavy  Offline
UK
And plasti-gauge?
Why not? , will tell you if it fits or not , could even stick some to the parting lines before torqueing her down.....................if it don't fit it don't fit.
Re: Broke A Main Cap! [Re: camastomcat] #682092
04/27/10 10:04 PM
04/27/10 10:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Who knows without at least looking... I did replace
replace a cap once but I had to do some minor work
on the cap to have it fit right(at least right enough
to work) and that engine ran fine for a long time
He11 you should have the bore checked if you put in
studs and I've got away with doing that also....
I know that I would be turning the engine over
a FEW times if the plastagauge looked good just
to make sure that the bearing didnt show anything
weard........this is just MY opinion
Re: Broke A Main Cap! [Re: MR_P_BODY] #682093
04/27/10 10:19 PM
04/27/10 10:19 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I guess what I would be thinking if it were mine is, if the main cap was broken, chances are that detonation caused it. And I think there is a good chance that with the kind of detonation causing that type of issue, the other caps have been stressed pretty hard too. When he takes the cap to the machine shop, they'll be able to tell him if they can fix it, but I would just pull the motor and go through it. It has lived a good life but needs to be looked at. And it's just my opinion, but that's the way I do things, right or wrong. It's a dangerous sport and there is no reason to take chances. Again JMO.
Re: Broke A Main Cap! [Re: camastomcat] #682094
04/27/10 10:28 PM
04/27/10 10:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I agree, thats why I said to look at the other caps
to see if they are hurt OR if you can see any signs
of what the cause was.... he might want to have the
others magna checked to be sure they are ok.... I
myself would pull the engine down but I pull my
engine all the time(only takes me 45 minutes to have
the engine and trans sitting on the ground)
Re: Broke A Main Cap! [Re: MR_P_BODY] #682095
04/28/10 12:02 AM
04/28/10 12:02 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I guess it wouldnt hurt to check... If you had a couple of blocks laying around and plenty of time...Remeber there is reason not to try any and all the other blocks caps..except the center...Unless you just wanted the number to be correct..
The chances are pretty slim imo that another cap will be close enough not to cause trouble....We re talking about the thickness of a piece of regular note book paper sliced in several layers here.
Heck a human hair is about 2-3x's the the thickness of bearing clearance. Not only does the cap half to be centered, but the thickness in every angle must be perfect.
Re: Broke A Main Cap! [Re: Bob_Coomer] #682096
04/28/10 10:39 AM
04/28/10 10:39 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Not a main but a rod cap in a 360 my brother had.It had a bad bearing.Pulled a rod cap from a 360 I had installed with new bearing.It ran for 4 years after that then he sold the van to a guy I knew and he put 4 years on it and it still ran.Sometimes you get lucky.Rocky
Chrysler Firepower
