Fuel Blowing Our My Carb? #681896
04/27/10 04:25 PM
04/27/10 04:25 PM
Empire, MI
V
Valiant451 Offline OP
V
Empire, MI
I just rebuilt my 451 and tried to turn it over, but the fuel is going the wrong direction? (Up Not Down) I havn't hooked up the coil yet, just turned it over with the fuel pump hooked up. I have read that the carb floats could be stuck. Any suggestions?
Re: Fuel Blowing Our My Carb? [Re: Valiant451] #681897
04/27/10 11:19 PM
04/27/10 11:19 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Could be crap between the needle and seat. pretty common to get a little sliver from the fuel hose caught up in there.
Re: Fuel Blowing Our My Carb? [Re: forphorty] #681898
04/28/10 10:21 AM
04/28/10 10:21 AM
Empire, MI
V
V
Empire, MI
Does any one think this is a timing problem?
Re: Fuel Blowing Our My Carb? [Re: Valiant451] #681899
04/28/10 10:41 AM
04/28/10 10:41 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Can you clarify that the fuel is coming out of carb vents, or if the carb is spitting back through throat?
Re: Fuel Blowing Our My Carb? [Re: buildanother] #681900
04/28/10 10:45 AM
04/28/10 10:45 AM
Empire, MI
V
V
Empire, MI
The fuel was coming out of the primarys and secondarys. I closed my choke and it came out the vent.
Before it came out the vent it looked like it was boiling, but there was allot of fuel coming out.
Re: Fuel Blowing Our My Carb? [Re: Valiant451] #681901
04/28/10 11:01 AM
04/28/10 11:01 AM
canada
Y
yakpenoose Offline
yakpenoose  Offline
Y
canada
give the carb a couple taps with a hammer,needle is stuck open....or they arent set right....or you have too much fuel pressure
Re: Fuel Blowing Our My Carb? [Re: yakpenoose] #681902
04/28/10 11:38 AM
04/28/10 11:38 AM
Empire, MI
V
V
Empire, MI
I know I don't have to much pressure, I used the same fuel pump on this engine with heads that didn't flow anything like the 906's I ported and polished.
I'm ripping the carb off and rebuilding it. It was sitting for a while.
