88 Dakota V6 to V8 swap #680453
04/26/10 04:14 AM
04/26/10 04:14 AM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
Just picked up an 88 Dak 3.9, 5spd. Would like to swap in a 360 and 727. Anyone done this? Thinking maybe early electronic ignition, and carb. Any problems I should be aware of? Will the rear end hold up? Looking for a fun parts chaser.
Re: 88 Dakota V6 to V8 swap [Re: elmor] #680454
04/26/10 08:35 AM
04/26/10 08:35 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i think you will have fan/radiator clearence problems. the first generation shelby dakotas were the only ones to have v8`s and they used electric fans. the 2nd gen. dakotas got a restyled grill/frontend to fit a v8. the rear in the 87 i had didn`t hold up to the stock v6, the carrier bearings went bad. i might have just had a bad rear from the start though.
Re: 88 Dakota V6 to V8 swap [Re: 65rbdodge] #680455
04/26/10 12:49 PM
04/26/10 12:49 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
I swapped my 89 to a 408 and 727. I used Schumaker motor mount and trans mount kit top do the swap. I also completely removed the electronic computer and things like that. I used MSD ignition and a set od shorty headers until I found a set of long tube headers. I run a stock V-6 radiator and a large pusher fan. You will also need to use a shorter steel water pump that exits on the drivers side. I plumbed mine under the balancer and over to the passenger side. This stays cool around town.
Re: 88 Dakota V6 to V8 swap [Re: 65rbdodge] #680456
04/26/10 01:02 PM
04/26/10 01:02 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
i built a 88 dakota with a 318/727 83/4 rear,i built this about 10 yrs ago.u can use the mopar ignition system,i originally did that then upgraded to a msd6al box.radiator will fit,i tucked mine up in the core support some,rear i would upgrade.i used a 67 b-body 8 3/4.u can use manifolds or have to build headers as no one makes them for that dakota anymore,hooker use too.heres some pics
Re: 88 Dakota V6 to V8 swap [Re: hp340nos] #680457
04/26/10 01:04 PM
04/26/10 01:04 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
drivers side mount. i used carboard for a template to get the correct angle.then transferred it to 1/4" plate had it bent and boxed it it.
Re: 88 Dakota V6 to V8 swap [Re: hp340nos] #680458
04/26/10 01:06 PM
04/26/10 01:06 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
passenger side mount
Re: 88 Dakota V6 to V8 swap [Re: hp340nos] #680459
04/26/10 01:08 PM
04/26/10 01:08 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
radiator pic from drivers side,4 core brass/copper radiator w/16" zirgo electric fan
Re: 88 Dakota V6 to V8 swap [Re: hp340nos] #680460
04/26/10 01:09 PM
04/26/10 01:09 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
radiator view from top looking down
Re: 88 Dakota V6 to V8 swap [Re: hp340nos] #680461
04/26/10 03:15 PM
04/26/10 03:15 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
If you do go with full length headers, you will have to drop the fuel tank. Summit still carries headers for this swap.
Re: 88 Dakota V6 to V8 swap [Re: elmor] #680462
04/26/10 05:45 PM
04/26/10 05:45 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Check on the MOPAR ACTION website. They did the same thing. The project was called " Project Scat Dak".
Re: 88 Dakota V6 to V8 swap [Re: Posest] #680463
04/09/13 11:43 PM
04/09/13 11:43 PM
jeff500 Offline
jeff500  Offline
Please explain what exactly you had to do to delete the computer and all the garbage...lol
