Are AAR hood pins the same as other cudas? #680422
04/26/10 12:49 AM
04/26/10 12:49 AM
Spring, TX
70cudaproject Offline OP
Spring, TX
Well I'm getting ready to buy the hood pins for my AAR hood. I read they are riveted on AARs, but are they the same as other Cuda hood pins?
Are the reproduction hood pin brackets close to the originals?
THANKS!
Kent
Re: Are AAR hood pins the same as other cudas? [Re: 70cudaproject] #680423
04/26/10 10:13 AM
04/26/10 10:13 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
The chrome bezels that rivet to the hood are different that the ones that are held on a sheet metal hood with screws. The holes are different for either rivets or screws. Other than that the rest of the kit is the same - cables, clips, pins, etc. The aftermarket kits use a serrated lock washer but the originals used a flat washer.
