68 Roadrunner, Flat black dimensions #680390
04/25/10 10:23 PM
04/25/10 10:23 PM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Does anyone have the layout of the flat black areas on a 68 Road Runner Hood?
What paint was used? Hopefully not Organisol...
Re: 68 Roadrunner, Flat black dimensions [Re: sthemi] #680391
04/25/10 10:56 PM
04/25/10 10:56 PM
United States
V
v269 Offline
v269  Offline
V
United States
Re: 68 Roadrunner, Flat black dimensions [Re: v269] #680392
04/26/10 10:37 PM
04/26/10 10:37 PM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Thanks V269 for the link...
Re: 68 Roadrunner, Flat black dimensions [Re: sthemi] #680393
04/27/10 01:06 PM
04/27/10 01:06 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I love that archived stuff... I read the original post and thought that I posted the info somewhere... Glad you found it
Re: 68 Roadrunner, Flat black dimensions [Re: 68jim] #680394
04/27/10 09:03 PM
04/27/10 09:03 PM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Jim,
Thanks for that great photo, the pics in the archived thread have been taken down..
I have a few more days of block sanding primer, before I need to put the hood treatment on...
Re: 68 Roadrunner, Flat black dimensions [Re: sthemi] #680395
04/27/10 09:44 PM
04/27/10 09:44 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Paint the base/clear first. Cut and buff then do hood treatment. SEM trim black is excellent for the hood treatment.
Re: 68 Roadrunner, Flat black dimensions [Re: Dougsmopars] #680396
04/28/10 12:25 PM
04/28/10 12:25 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Hi sthemi, your welcomed to come over to my house to measure my hood, from what i have seen mine looks correct. RT59 and I-88 here. Mike
Re: 68 Roadrunner, Flat black dimensions [Re: ademon] #680397
04/28/10 12:26 PM
04/28/10 12:26 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
one more
Re: 68 Roadrunner, Flat black dimensions [Re: sthemi] #680398
04/28/10 12:56 PM
04/28/10 12:56 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
hope I'm not too late?
MikeR
Re: 68 Roadrunner, Flat black dimensions [Re: A12] #680399
04/28/10 01:01 PM
04/28/10 01:01 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
larger photo (same)
Re: 68 Roadrunner, Flat black dimensions [Re: A12] #680400
04/28/10 03:20 PM
04/28/10 03:20 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I just posted the photos above because I had them not because they are right or wrong but I noticed that the black is not to the scoop insert edge on the photos I posted. I think I have seen some to the edge so that brings up the question; "which is correct"?.....................hate doing that but I never noticed that before, sorry. Wish there was a factory drawing because I would like to add it to my '68 rr, always liked that blackout. I ordered my '69 rr in '69 with the flat black stripes cause it was cool so was the '68.
MikeR
Re: 68 Roadrunner, Flat black dimensions [Re: A12] #680401
04/28/10 04:30 PM
04/28/10 04:30 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
MikeR
Mike, Mine was to the edege of the insert on the org paint. Here's a pic after paint but blackout is in the org. location.
Re: 68 Roadrunner, Flat black dimensions [Re: rrunner] #680402
04/28/10 10:07 PM
04/28/10 10:07 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I can't seem to find the pictures I had taken a few years ago but all three of the original 68 hoods I found had the paint line (on the hood) across the outer holes for the scoops. That made the scoops themselves as the outer edge of the patern...does that make sense???
Re: 68 Roadrunner, Flat black dimensions [Re: 68jim] #680403
04/28/10 10:15 PM
04/28/10 10:15 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
This is the best one I can find now of how the outer paint line went back on. I'm not sure if I have any of the reference shots anymore...sorry...
Re: 68 Roadrunner, Flat black dimensions [Re: 68jim] #680404
04/28/10 10:33 PM
04/28/10 10:33 PM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Jim,(and everyone else)
thanks for the photos, the Red /Black combo is very striking....
I will post some pics when I get mine painted..., just back from laying on some more sanding primer...
Re: 68 Roadrunner, Flat black dimensions [Re: sthemi] #680405
04/29/10 09:01 AM
04/29/10 09:01 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I found one more shot I can share but still no old reference pics...
Good luck!!
Re: 68 Roadrunner, Flat black dimensions [Re: 68jim] #680406
04/29/10 01:44 PM
04/29/10 01:44 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The silver hood photos appear to show an incorrect pattern, too large and extending past the hood inserts; basically as stated & shown by 68jim, the inserts (scoops) are the rt & lt outer perimeter of the finished blackout, and the line straight across the back and vectored off the front of the scoops are the front & rear edges. Measuring straight from the front, you can see that the angles meet in the center. It's basically a pentastar, which is kind of amusing.
