Master cylinder. How hard is it....
#680380
04/25/10 10:13 PM
04/25/10 10:13 PM
Posts: 1,630 North Central Florida
eightlitermopar
How hard is it really to change a master cylinder? 69 dodge coronet, already have the part from Napa I know I need to bench bleed it first, but is there anything I need to know before I tear into this? When I come to a stop (automatic) I push on the brake and it slooooowwwwllyy depresses all the way to the floor. It's getting more scarey and it's time to be changed! thanks! eight
Mopar or no car
Re: Master cylinder. How hard is it....
[Re: eightlitermopar]
#680382
04/25/10 11:13 PM
04/25/10 11:13 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
Yeah, if no brake fluid is leaking anywhere , your MC is bad. Really not a bad job; especially if its power brakes. Bolts to the booster under the hood. If they are manual, the worst part is reaching the bolts inside on the fire wall. It's easier with a helper. Otherwise, everything else is the same; Bench bleed, install, bleed rest of the system.
[Re: Scott Carl]
#680383
04/26/10 02:19 AM
04/26/10 02:19 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Bench bleed the new cylinder, attach it to the lines but do not tighten them. Have a helper push the pedal down then snug up the lines.. Then you can bleed the system at the master culinder lines and avoid trying to break off all 4 bleeder screws... Simply pump up pressure and loosen the line at the front or back line until no air escapes when you crack it open..Keep refilling the cylinder as needed. Do one line at a time until you have a solid pedal.
[Re: sthemi]
#680384
04/26/10 07:22 AM
04/26/10 07:22 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Since no one else said it use some penetratibg oil on the lines to the master also.Lots of times the fittings wont turn and the lines will snap off.That and use a line wrench on them.Rocky
Chrysler Firepower
[Re: Sixpak]
#680388
04/26/10 01:35 PM
04/26/10 01:35 PM
Posts: 5,447 So Cal
Sinitro
So Cal
MAKE SURE you correctly install whatever type of push rod retainer is used for your application. Some use that little rubber piece that slips over the push rod and snaps into the back of the master; some use a screwed on retainer at the back of the master. Sucks when your push rod falls out of the master cylinder, especially when hitting the brakes at top end of a drag strip (DAMHIK! lol)
GREAT ADVICE!!
A friend, knowledgible about Mopars had the pushrod pull out of the MC when going through the lites @ 130 MPH...
Not pretty as he tore up the front end of his car going through the barrels and sandpit..
Just my $0.01..
