Page 1 of 3 1 2 3
Help my doggy 383 #680155
04/25/10 08:30 PM
04/25/10 08:30 PM
NJ
440challenger Offline OP
NJ
Dont have all the specs but i bought this motor used about 6 years ago. It was rebuilt and runs great,but just feels underpowered.
I have had it in my roadrunner for about 3 years.
Its a 383, SRP pistons?, mopar hydraulic purple shaft unknown lift/duration, 906 heads,eddy perf intake,Bigs 780 vac carb, headers. msd ignition,timing at 38 total.
Its an auto,2800 converter,4.11 gear.
Car runs great, besides it feeling underpowered.
it doesnt have the pull that puts you back in the seat. I just got done building a smog 440 with the a summit cam it it will destory this mild 383. Is this just the nature of a mild 383 with (im guessing) low compression?
Anything you guys reccomend doing/checking?
thanks!
Re: Help my doggy 383 [Re: 440challenger] #680156
04/25/10 09:02 PM
04/25/10 09:02 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
If the engien really is runnign OK, then there is little you can do short of putting in a bigger cam and/or aftermarket heads. CR might be a bit low though for aluminum heads.
I would say look at things to lighten up the car, it will make it easier to get moving and might even help you out a bunch if you have manual steering. I know it sure made my 69 RR MUCH easier to live with when I was albe to cut some wieght with aluminum WP and housing, alng with a mini starter and ditching my iron intake. Aluminum master is next when the time comes.
Short of that, not much you can do. My RR had more grunt with the 440, but the 383 is fine for my use. Just will never have the pop the big engine did. Of course I get better MPG now...
I want my fair share
Re: Help my doggy 383 [Re: 440challenger] #680157
04/25/10 09:08 PM
04/25/10 09:08 PM
thanks!
Get a baseline on what you have now: compression test/leakdown test/idle vacuum/initial timing/slot curve/mixture. I'd advance the cam 4 deg for a start to effect some gain that you can feel keeping in mind that it'll decrease the PV clearance on either the intake or the ex valves (not sure which).
Re: Help my doggy 383 [Re: SomeCarGuy] #680158
04/25/10 09:09 PM
04/25/10 09:09 PM
NJ
NJ
I have alum master w/ maunual brakes. maunual steering. Alum rad.
It cruizes good, Just it not fun to drive without that grunt. I dont know if im used to driving my challenger (low 11 sec street car) or if i can get more out of this 383 combo. Im going to check my inital timing tommrow and see where im at.
I found a video on you tube that kind of shows how my motor acts. its not as slow as the one on youtube but it resembles the same traits as how it takes for ever to wind out and doesnt go anywhere
http://www.youtube.com/watch?v=5g6M9daFPh4
Re: Help my doggy 383 [Re: 440challenger] #680159
04/25/10 09:16 PM
04/25/10 09:16 PM
NJ
NJ
I was thinking about advancing the cam. I see mopar preformance makes a bushing kit. How does that work on a big block?I have used the woodruff keys before but not a bushing.
Re: Help my doggy 383 [Re: RapidRobert] #680160
04/25/10 09:21 PM
04/25/10 09:21 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
thanks!
at least 4 deg on a purple shaft maybe 6 will really wake it up.
Re: Help my doggy 383 [Re: Dodgem] #680161
04/25/10 09:37 PM
04/25/10 09:37 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Them cars would put you back in the seat bone stock. If yours is doggie i'd look into the combo and find whats not matching up. Check cam timing. I've seen people install them 4 degree retarded car was a stone dog. 4 degree advance will give a boot to bottom end. I don't use offset keys i use timing sets with advance notches. If your gonna pull it apart to degree the cam thats the time to throw a new chain in.
Re: Help my doggy 383 [Re: 440challenger] #680162
04/25/10 09:39 PM
04/25/10 09:39 PM
you wouldn't happen to have some SB offset keys on hand would you . Heres my BB ones. You drill out the locating pin hole so the round BB bushings will fit and pick the one you want/install it and turn it to offset it to make it turn the cam sprocket CW then stake it/epoxy it in place
Re: Help my doggy 383 [Re: 440challenger] #680163
04/25/10 09:47 PM
04/25/10 09:47 PM
Illinois
moparmattkos Offline
mopar addict
mopar addict
Illinois
it doesnt have the pull that puts you back in the seat. Anything you guys reccomend doing?
Hope this helps ,I have enclosed a pic of my last motor that felt underpowered! I just put a small nos kit on it and it woke up quite a bit!
www.sikosracing.net Heads up Drag racing
Re: Help my doggy 383 [Re: moparmattkos] #680164
04/25/10 09:51 PM
04/25/10 09:51 PM
Dougsmopars Offline
Dougsmopars  Offline
WOW!!!! thats a lot of fittings. lol
Re: Help my doggy 383 [Re: Dougsmopars] #680165
04/25/10 10:04 PM
04/25/10 10:04 PM
NJ
NJ
LOL! Ok if i get a new timing set which one do you guys reccomend? With an adjustable timing set would i just be able to put the motor on tdc and then set the sprocket to the 4deg advance dot or do i need to get pretty involved and get a degree wheel ?
Re: Help my doggy 383 [Re: 440challenger] #680166
04/25/10 10:07 PM
04/25/10 10:07 PM
SomeCarGuy Offline
SomeCarGuy  Offline
I used to run only Comp Cams chains, now I don;t know if I would use them based on the problems I see posted here with all of their current offerings
I had a Roll Master set a couple of years ago that was really tight. Really tight. I would think it would hold up well. Sold the engien, so???
Re: Help my doggy 383 [Re: 440challenger] #680167
04/25/10 10:08 PM
04/25/10 10:08 PM
both, cant assume ANY part is correct
Re: Help my doggy 383 [Re: RapidRobert] #680168
04/25/10 10:23 PM
04/25/10 10:23 PM
Dougsmopars Offline
Dougsmopars  Offline
I use the Summit true roller chain and gear set. Yup TDC drop it in on the 4 degree advance notch. Car runs super. Now if this were a big dollar Hemi roller motor or a motor for an all out race car i'd go the degree wheel root. For a street car dot to dot is fine. Repair shops have been replacing timing chains for 50 years just doing dot to dot. Yes it may in reality be 1 degree either way but runs fine.
Re: Help my doggy 383 [Re: 440challenger] #680169
04/25/10 10:53 PM
04/25/10 10:53 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'll guess it's you convert/cam combo. Purple shafts cams need some stall. swap the cam on the converter
Coming soon!!!!
Re: Help my doggy 383 [Re: Mr.Yuck] #680170
04/26/10 08:40 AM
04/26/10 08:40 AM
NJ
NJ
Heres what i found.
http://www.summitracing.com/parts/SUM-G6604-B/
Are most the hydraulic purple shafts 1 bolt or 3 bolt or could they be either? I'd like to order the parts before i rip everything apart.
Re: Help my doggy 383 [Re: 440challenger] #680171
04/26/10 08:55 AM
04/26/10 08:55 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
most of them are one bolt!
you should look at one of these
http://www.summitracing.com/parts/SUM-G1056/
You would need one solid lifter too and a solid pushrod is nice to run up to the dial indicator
one of these is real nice
http://chucker54.stores.yahoo.net/crtusowidewh.html
summit
http://www.summitracing.com/parts/CCA-4799/
in use nice the degree whee goes right in it I did put a couple extra set screws in as you use the small keyway and the set screw is hard to get at
Re: Help my doggy 383 [Re: Dodgem] #680172
04/26/10 08:57 AM
04/26/10 08:57 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
another
Re: Help my doggy 383 [Re: Dodgem] #680173
04/26/10 08:59 AM
04/26/10 08:59 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
back
Re: Help my doggy 383 [Re: Dodgem] #680174
04/26/10 08:59 AM
04/26/10 08:59 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
alone on crank
Page 1 of 3 1 2 3
