63-64 Plymouth Max Wedge hood holes help #679897
04/25/10 02:57 PM
04/25/10 02:57 PM
Sullivan, Ohio
Max Wedge Savoy Offline OP
Sullivan, Ohio
I'm in a bit of a jam right now. My body man is waiting on me to cut the holes in my hood before he preps and paints it. I bought a template off ebay and it appears that its for a Dodge (non tapered hood). I have contacted the template vendor and he is working with me but I am starting to become uneasy about it. My question is this, does anyone have a 63-64 Plymouth maxie with cut outs? If so, could I get a little assistance with locating the correct position to cut the holes? Thanks in advance.
Re: 63-64 Plymouth Max Wedge hood holes help [Re: Max Wedge Savoy] #679898
04/25/10 05:25 PM
04/25/10 05:25 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
You might want to post this over in the race section There are quite a few Max cars in NE Ohio and a few of them frequent the race forum.
Gus
64 Plymouth Savoy
Dana 60
383man [Re: fourgearsavoy] #679899
04/25/10 05:37 PM
04/25/10 05:37 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Took this pic of Mosher's site. Its a 63 Ply hood. Hope ot helps. Ron
Re: 383man [Re: 383man] #679900
04/26/10 11:50 AM
04/26/10 11:50 AM
Sullivan, Ohio
Sullivan, Ohio
Thanks 383man. I did post the same thing in the race forum.
Re: 383man [Re: Max Wedge Savoy] #679901
04/26/10 12:12 PM
04/26/10 12:12 PM
btomasko Offline
btomasko  Offline
You might try hemi eddy, I think he has a template he sells
Re: 383man [Re: Max Wedge Savoy] #679902
04/26/10 12:13 PM
04/26/10 12:13 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You might also try installing an air cleaner stud in each carb that will contact the hood when you close it. Close the hood enough to mark the underside with a gouge or small dent, then measure out the circle you need from there.
IIRC, the hole size matches the inside diameter of the seals that were attacked to the air bells (the spun aluminum pieces).
