Help- Degree Cam #679619
04/25/10 04:07 AM
04/25/10 04:07 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Ok, I cannot and will not understand this procedure. I feel like an idiot.
Here are the instructions I tried :
http://www.hughesengines.com/Upload/productInstructions/Cam_Instruction_Bundle2NEW.pdf
Please dont try to explain all this because I just dont get it, BUT , i want to list the numbers i came up with and maybe you guys can tell me where Im at.
I made it thru all the steps ( i think) .
SO- towards the end ....Under "Checking the open/close of intake lobe" in the Pdf file above ,
step 3 = i get 256 ( or 76) on my degree wheel
step 4 = i get 234 (or 54) on the degree wheel.
after that Im lost. I find the rest too confusing and Im not THAT bad at math.......
Re: Help- Degree Cam [Re: 493_DART] #679620
04/25/10 06:04 AM
04/25/10 06:04 AM
Australia
W
wogboy Offline
wogboy  Offline
W
Australia
Have you done a search on utube? there are many videos with visual aid.
Re: Help- Degree Cam [Re: 493_DART] #679621
04/25/10 07:09 AM
04/25/10 07:09 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i don't know how you're getting the number on step 3, thats way too high.
Re: Help- Degree Cam [Re: 493_DART] #679622
04/25/10 08:58 AM
04/25/10 08:58 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Are you sure you are measuring the #1 cylinder "INTAKE" lobe?
The INTAKE lobe is actually the SECOND lifter bore from the front of the engine on the drivers side.
The FIRST lifter bore is the EXHAUST lobe.
Re: Help- Degree Cam [Re: 493_DART] #679623
04/25/10 09:23 AM
04/25/10 09:23 AM
UK
602heavy Offline
602heavy  Offline
UK
Maybe list the cam specs.
It may help if you dial in the intake centreline , then fine tune the open/close points.
Re: Help- Degree Cam [Re: 493_DART] #679624
04/25/10 09:27 AM
04/25/10 09:27 AM
NC
440Jim Offline
440Jim  Offline
NC
To get an idea of what is going on, you need to list the measurements as "BTC" or "ATC" etc. Some degree wheels have 54 degrees marked as before and some after, for example. So, sometimes you have to read backwards on the wheel to take a reading.
ie the pointer is at 54 "BTC", but the formula needs "ABC"
Re: Help- Degree Cam [Re: 440Jim] #679625
04/25/10 09:39 AM
04/25/10 09:39 AM
NC
440Jim Offline
440Jim  Offline
NC
Maybe this pic is a better example. The black line is at 80 BTC (BTDC), but also could be read as 100 ABC (ABDC).
Re: Help- Degree Cam [Re: 440Jim] #679626
04/25/10 10:03 AM
04/25/10 10:03 AM
NC
440Jim Offline
440Jim  Offline
NC
This is how I read Hughes instructions:
Example 2: Using a larger camshaft where the intake opens before TDC with a 107 lobe separation angle.
If for example the intake should open at 21 BTC (Before Top Center) and close at 49 ABC. Add the 21 BTC
and the 180 (from TDC to BDC) and the 49 ABC, which totals 250 Divide the 250 by 2, this is 125
ie the installed centerline is 125 degrees from the opening (or closing) point. So intake installed centerline is 125-21 or 104 ATC. It should look like this attachement.
Re: Help- Degree Cam [Re: 493_DART] #679627
04/25/10 10:13 AM
04/25/10 10:13 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Help- Degree Cam [Re: Dodgem] #679628
04/25/10 10:28 AM
04/25/10 10:28 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
440jim shows it nicely on his wheel the lifter should move .050 off its base somewhere before TDC and be .050 from its base after BDC.
Lets say it is a 250 intake duration cam at .050
say its 20 BTDC and 50 ABDC
you take the 250/2 + 125
then since you got 20 BTDC you take that from the 125 - 20 = 105 so your intake centerline / max lift would be at 105 ATDC
Re: Help- Degree Cam [Re: 493_DART] #679629
04/25/10 12:41 PM
04/25/10 12:41 PM
The way I read the instructions your referring to is for checking the cam at .050 intake lifter lift from OPENING to .050 before closing or the duration at .050 lifter timing. These readings need to be done in relation to top dead center on the opening specs and after bottom dead center on the closing specs, try checking it that way and use the degrees before top dead center, BTDC( you may need to count backwards on your degree wheel) and the degrees after bottom dead center, ATDC. Let us know if that helps, if so we can help you do the intake lobe seperation angle also It is to bad that there are so many ways for the makers of degree wheels and company that offer instruction to confuse us racers
Re: Help- Degree Cam [Re: Cab_Burge] #679630
04/25/10 04:00 PM
04/25/10 04:00 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
im going to post pics of the 2 readings i got .
Maybe that will help. Everything you all just posted above makes no sense to me . My brain just cant compute it and i dont know why
YES--im on the #1 INTAKE lifter.
I have to go to work now, I will post pics in about 8 hours
Re: Help- Degree Cam [Re: 493_DART] #679631
04/25/10 08:57 PM
04/25/10 08:57 PM
tboomer Offline
tboomer  Offline
Post your cam specs,Kevin...
Re: Help- Degree Cam [Re: tboomer] #679632
04/25/10 09:29 PM
04/25/10 09:29 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
1) Find top dead center by using a positive stop rotating clockwise until it stops, take reading on degree wheel.
2) Then turn it counterclockwise take another reading when it stops, then split the difference of the 2 readings and set the degree wheel to 0.
3) Then set indicator up on the deck surface with a pushrod (on intake lobe) contacting the indicator rotated clockwise to find max lift.
4) Then set the indicator to 0 and rotate clockwise to .050 after max lift take the reading on degree wheel.
5) Then turn clockwise to .050 before max lift took another reading off the degree wheel.
140*+80*=220*/2=110
Mopar Performance
Re: Help- Degree Cam [Re: moparniac] #679633
04/26/10 12:34 AM
04/26/10 12:34 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
here is the wheel after step 3 from hughes instructions :
Re: Help- Degree Cam [Re: 493_DART] #679634
04/26/10 12:35 AM
04/26/10 12:35 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
after step 4 -
Re: Help- Degree Cam [Re: 493_DART] #679635
04/26/10 12:38 AM
04/26/10 12:38 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
cam is a 108
says installed 105 .
However , hughes says they have 3 degrees advance already ground into the cam.
Im lost .
Re: Help- Degree Cam [Re: 493_DART] #679636
04/26/10 12:47 AM
04/26/10 12:47 AM
Someting is diffently not correct on those readings, is picture number one of the degree wheel with the lifter raise up .050 from beginning to open? If not it needs to be. Also is picture #2 with the lifter .050 from closing all the way? If not it needs to be Let us know
Re: Help- Degree Cam [Re: 493_DART] #679637
04/26/10 12:58 AM
04/26/10 12:58 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
What is the @ .050 intake duration and make sure you are starting with the lifter on the base circle.
The pic of the step 3 looks WAY off to me. If the cam is 270 @ .050 the intake open event at .050 should be about 27* before TDC, that pic looks like 104* BTDC
If you put the timing chain on, line up the dots and have an accurate TDC indicated on the degree wheel, turn the crankshaft counter clockwise about 180-230* to get the lifter on the base circle and start from there zeroing out the dial indicator on the lifter.
Re: Help- Degree Cam [Re: Cab_Burge] #679638
04/26/10 02:30 AM
04/26/10 02:30 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
the pics are labeled---
1st is after step 3.
2nd is after step 4.
Re: Help- Degree Cam [Re: RobX4406] #679639
04/26/10 02:31 AM
04/26/10 02:31 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
cam duration is 268 / 272 at .050 , 108 cl
Im going to try this again monday with the Comp instructions and i will take notes after each step and post what i get .
Re: Help- Degree Cam [Re: 493_DART] #679640
04/26/10 07:21 AM
04/26/10 07:21 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If this is the Hughes HTL6872BS3 cam:
268/272 at 0.050"
Intake Opens at 0.050" = 29 BTDC
Intake Closes at 0.050" = 59 ABC
The first photo does not make sense,
The second photo shows the cam off by 5-degrees?
Re: Help- Degree Cam [Re: 451Mopar] #679641
04/26/10 08:44 AM
04/26/10 08:44 AM
Johnstown ohio
BluCuda Offline
BluCuda  Offline
Johnstown ohio
Are you using a solid lifter to degree your cam? If you are using a hydraulic you will not get the correct numbers on the degree wheel.
Re: Help- Degree Cam [Re: 451Mopar] #679642
04/26/10 09:50 AM
04/26/10 09:50 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
268/272 at 0.050"
first makes no sense and by the second you have it installed 100 intake centerline (max lift) advanced 5 deg from where the suggested install is?
yes Hughes has cam designed so that in theory lining the dotes up would put it at 105 intake centerline right where he wants it
Re: Help- Degree Cam [Re: Dodgem] #679643
04/26/10 10:05 PM
04/26/10 10:05 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
I apologize guys , for any wasted time here........
I ran thru it again today and nothing made sense.
IM out!
SO , I left it "straight up"
too late now, its buttoned up , im getting the heads on it tonight and maybe back in the car.
Going to see how she runs. If i need to try advancing it 4 degrees this summer- no big deal .
Re: Help- Degree Cam [Re: 493_DART] #679644
04/26/10 11:26 PM
04/26/10 11:26 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
No big deal, running it straight up will work, maybe not as good as advanced or maybe just as good. We all have brain fade sometimes.
Re: Help- Degree Cam [Re: rowin4] #679645
04/27/10 02:43 AM
04/27/10 02:43 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
the older i get , the more i have that brain fade ............
If i need to go 4 degrees one way or the other , i can do it later ....the cam is from Hughes so Im confident it will work either way
