Re: Help- Degree Cam [Re: RobX4406] #679639
04/26/10 02:31 AM
04/26/10 02:31 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
What is the @ .050 intake duration and make sure you are starting with the lifter on the base circle.
The pic of the step 3 looks WAY off to me. If the cam is 270 @ .050 the intake open event at .050 should be about 27* before TDC, that pic looks like 104* BTDC
If you put the timing chain on, line up the dots and have an accurate TDC indicated on the degree wheel, turn the crankshaft counter clockwise about 180-230* to get the lifter on the base circle and start from there zeroing out the dial indicator on the lifter.
cam duration is 268 / 272 at .050 , 108 cl
Im going to try this again monday with the Comp instructions and i will take notes after each step and post what i get .
Re: Help- Degree Cam [Re: 493_DART] #679640
04/26/10 07:21 AM
04/26/10 07:21 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If this is the Hughes HTL6872BS3 cam:
268/272 at 0.050"
Intake Opens at 0.050" = 29 BTDC
Intake Closes at 0.050" = 59 ABC
The first photo does not make sense,
The second photo shows the cam off by 5-degrees?
Re: Help- Degree Cam [Re: 451Mopar] #679641
04/26/10 08:44 AM
04/26/10 08:44 AM
Johnstown ohio
BluCuda Offline
BluCuda  Offline
Johnstown ohio
Are you using a solid lifter to degree your cam? If you are using a hydraulic you will not get the correct numbers on the degree wheel.
Re: Help- Degree Cam [Re: 451Mopar] #679642
04/26/10 09:50 AM
04/26/10 09:50 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
268/272 at 0.050"
first makes no sense and by the second you have it installed 100 intake centerline (max lift) advanced 5 deg from where the suggested install is?
yes Hughes has cam designed so that in theory lining the dotes up would put it at 105 intake centerline right where he wants it
Re: Help- Degree Cam [Re: Dodgem] #679643
04/26/10 10:05 PM
04/26/10 10:05 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
I apologize guys , for any wasted time here........
I ran thru it again today and nothing made sense.
IM out!
SO , I left it "straight up"
too late now, its buttoned up , im getting the heads on it tonight and maybe back in the car.
Going to see how she runs. If i need to try advancing it 4 degrees this summer- no big deal .
Re: Help- Degree Cam [Re: 493_DART] #679644
04/26/10 11:26 PM
04/26/10 11:26 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
No big deal, running it straight up will work, maybe not as good as advanced or maybe just as good. We all have brain fade sometimes.
Re: Help- Degree Cam [Re: rowin4] #679645
04/27/10 02:43 AM
04/27/10 02:43 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
the older i get , the more i have that brain fade ............
If i need to go 4 degrees one way or the other , i can do it later ....the cam is from Hughes so Im confident it will work either way
