Did compression test,not happy,Can someone diagnose? #679326
04/24/10 09:06 PM
04/24/10 09:06 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
400-2v in my 73 Truck. Test was done after engine was run for about 10 minutes.Exhaust manifolds were still warm to the touch,but not HOT.
Pulled all plugs and had the pedal to the floor as I cranked the engine over. I counted to 8 on each cylinder as I cranked the engine over.
Results are as follows:
Cylinder 1.----90
Cylinder 2.----90
Cylinder 3.----60
Cylinder 4.----100
Cylinder 5.----110
Cylinder 6.----105
Cylinder 7.----100
Cylinder 8.----30
On the 2 low cylinders,I tested them at least 3 times as I thought I may not have the tester fully seated. All 3 times on those low cylinders,the numbers remained the same each time.
What might my issue be,and where do I go from here to repair this issue?
Dont know if it matters,but yesterday I pulled all the plugs out,shot each with carb cleaner as they were all fuel fouled,regapped em and reinstalled.
Today when I pulled em back out 3 of the 8 were sooty black and the rest were nice and brown(normal color)
Re: Did compression test,not happy,Can someone diagnose? [Re: SPWC] #679327
04/24/10 09:08 PM
04/24/10 09:08 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Put a little engine oil in these cylinders. If the compression comes way up it is going by the rings.
Re: Did compression test,not happy,Can someone diagnose? [Re: Posest] #679328
04/24/10 09:17 PM
04/24/10 09:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Cylinder pressure is leaking past either the rings or the valves. I would think it's probably running pretty roughly with that much difference among cylinders. Previous poster's suggestion is your next test. Oily plugs, blue smoke, lots of oil usage indicate worn-out rings. You can also do a leakdown test, and if you hear air escaping through the carb, that's an intake valve leak; through the tailpipe indicates exhaust valve leak.
With the readings you're getting, I'd be thinking rebuild.
Re: Did compression test,not happy,Can someone diagnose? [Re: topside] #679329
04/24/10 09:29 PM
04/24/10 09:29 PM
SPWC Offline OP
SPWC  Offline OP
Well It seems the valves are culprit. I added the oil as suggested,rechecked those cylinders and both of the low numbers stayed the same. Not that it mattered but I was able to muster a high of 70 on the one cylinder and the lowest number remained unchanged.
So is it time for another motor,or would swapping a set of known good heads fix the issue?
Re: Did compression test,not happy,Can someone diagnose? [Re: SPWC] #679330
04/24/10 10:00 PM
04/24/10 10:00 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Compression is pretty low, but consistent for all but two cylinders. Bring the suspect cylinder to TDC and add compressed air through the spark plug hole. Listen at the carb, tailpipe, oil fill and radiater. The sound of air leaking out the carb is a bad intake valve, tailpipe - exhaust valve, breather - rings, bubbles in radiator - cracked block/head or bad head gasket (unlikely in your scenario). Repeat for other low cylinder. You could also do a good cylinder for comparison on sounds. A poor-mans leak-down test. A pair of heads should fix it for a while if the rings are OK.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Did compression test,not happy,Can someone diagnose? [Re: SPWC] #679331
04/24/10 10:08 PM
04/24/10 10:08 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
Just a small tidbit, but was the battery on a charger during the test. If not, results will be skewed.
Re: Did compression test,not happy,Can someone diagnose? [Re: Pat_Whalen] #679332
04/24/10 10:19 PM
04/24/10 10:19 PM
SPWC Offline OP
SPWC  Offline OP
No there wasnt a Battery Charger hooked up. Myself and im sure others have never heard of doing a compression test with a battery charger hooked up.
Not at all saying its wrong...Just never heard of this detail.
Re: Did compression test,not happy,Can someone diagnose? [Re: SPWC] #679333
04/24/10 10:27 PM
04/24/10 10:27 PM
SPWC Offline OP
SPWC  Offline OP
As I try to locate a set of heads,would it be okay to continue to operate this vehicle? I know my performance and gas mileage will suffer,but will any further harm to the engine come from driving it daily in the condition its in?
Re: Did compression test,not happy,Can someone diagnose? [Re: SPWC] #679334
04/24/10 10:37 PM
04/24/10 10:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You shouldn't cause any more damage. I've know people that have driven quite a while with burnt valves. Just don't drive the crap out of it.
Re: Did compression test,not happy,Can someone diagnose? [Re: stumpy] #679335
04/24/10 10:49 PM
04/24/10 10:49 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Drove a slant 6 for a year with a burnt exhaust valve with no problems. Valve had a good notch in it by then, but head was repairable.
Re: Did compression test,not happy,Can someone diagnose? [Re: SPWC] #679336
04/24/10 11:05 PM
04/24/10 11:05 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
1975 was the first year that nearly all engines had induction hardened valve seats. If your heads are the original ones from '73 they may have never had hard seats to begin with. I once had an old slant six that I drove with three badly burned valves and it still ran. Very poorly, but it did run. If it were mine and I wanted to keep it for a long time I would consider buying either a set of remanufactured of '75 452 heads or better yet a set of stealth or Eddy heads.
Re: Did compression test,not happy,Can someone diagnose? [Re: 5spdcuda] #679337
04/25/10 06:00 AM
04/25/10 06:00 AM
scratchnfotraction Offline
I will refer to my last post on your other thred when you concluded it was a vac leak
I said a "burnt valve"
leak down test is in order along with a valve job
so...am I right now?
Re: Did compression test,not happy,Can someone diagnose? [Re: scratchnfotraction] #679338
04/25/10 07:48 AM
04/25/10 07:48 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Drive it till it dies. Drive the hell out of it you won't hurt a thing. It will be missing and down on power and use more gas but it won't matter a bit how you drive it. It will still miss and be down on power. In fact at higher RPM's it may intermittently pick up those cylinders.
Re: Did compression test,not happy,Can someone diagnose? [Re: MoparforLife] #679339
04/25/10 08:19 AM
04/25/10 08:19 AM
Columbia, Maryland
GTSGTXCUDA2 Offline
GTSGTXCUDA2  Offline
Columbia, Maryland
My 1972 340 Cuda was about a burning about a quart of oil every 100 miles. It knocked under light acceleration when the vacuum advance was in. I did wet and dry tests and found the valves were shot. I had similar concerns about an accurate test, and holding the gauge in tight enough. Put refurbished heads on the car, and the oil burning and the knocking stopped. Gas mileage went up and the car had a lot more power.
Re: Did compression test,not happy,Can someone diagnose? [Re: scratchnfotraction] #679340
04/25/10 01:02 PM
04/25/10 01:02 PM
SPWC Offline OP
SPWC  Offline OP
Ok ok ,I stepped on my d*** when I concluded that it was "only" a vacuum leak causing the issue.
It ran much better after I tightened the carb,so I thought I had the problem licked.
I then remembered about the compression test and figured I would cover all bases,which is what I should have done in the first place.
So now I know the truck runs "better" because I fixed the vacuum leak,but the truck has ALOT more improvement in it once I get the valve issues repaired.
I apologize for saying it was "Only" a vacuum leak causing the problem when in fact it was a burned valve issue as you suggested.
Again I thank you for your suggestion and hope I ruffled no feathers for "jumping the gun" on my diagnosis and concluding the problem was something other than what you had suggested.
Re: Did compression test,not happy,Can someone diagnose? [Re: SPWC] #679341
04/26/10 08:06 AM
04/26/10 08:06 AM
I was just jokin with ya
got to rule out mech failurs before you tune
Vac leak was a big part of the problem also,you ruled that mech problem out,and the weak cyls showed up a lot better..as it was not the whole fix
It was just a guess,i have had a bunch of old worn out engines
chased a miss for a long time on some of them till I removed the heads and could see the valve
on run the poop out of it,but it can get worse and cause more damage if you want to keep and salvage any of it
a sucked/droped valve is not pretty
did you do the air pressure check and "listen" to it?
Re: Did compression test,not happy,Can someone diagnose? [Re: scratchnfotraction] #679342
04/26/10 09:41 AM
04/26/10 09:41 AM
SPWC Offline OP
SPWC  Offline OP
I havent done the "leakdown" test yet due to not having access to Air Tools. I have a friend with a Compressor,and plan on talking to him about helping me do this.
Re: Did compression test,not happy,Can someone diagnose? [Re: SPWC] #679343
04/26/10 10:28 AM
04/26/10 10:28 AM
I havent done the "leakdown" test yet. I have a friend with a Compressor,and plan on talking to him about helping me do this.
you can take your compression tester hose and take out the shrader valve (just like a tire valve stem core) then run some air in and listen for where it's escaping. It wont give you percentage #'s like a leakdown gauge will but it'll tell you where especially if it's mainly from one area where you can hear it distinctly. carb (intake valve), tailpipe (exhaust valve), rad (head gasket/cracked head/block but highly unlikely on the last 2), oil fill neck (rings). EDIT each cyl you check have it on TDC compression
Re: Did compression test,not happy,Can someone diagnose? [Re: RapidRobert] #679344
04/26/10 03:31 PM
04/26/10 03:31 PM
P
Paul_Fancsali Offline
P
Before you do the heads run a can of Sea foam or other top cylinder lube threw the carb. It could be a piece of carbon holding the valve openI recently had a engine with 60 lb cyl run can threw the carb and stunk up the place but she shot back up to 135 plenty enough for a older engine
