Front suspension / alignment question. #677969
04/23/10 07:46 AM
04/23/10 07:46 AM
St. Clair Shores, Michigan
bigsbigelow Offline OP
What is the name of the plate that the cams for front wheel alignment ride on? The plates have two 90 degree bends at each end, a slotted hole, and the bolts for the upper control arms run through them. One of mine was cut by a previous owner for some obviously stupid reason and I am trying to see if I can get one new.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Front suspension / alignment question. [Re: bigsbigelow] #677970
04/23/10 10:31 AM
04/23/10 10:31 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I don't know the name but I'm pretty sure no one makes/repro that peice that welds into the shock tower assy. I'd think the closest you'd get is an whole NOS shock tower assy.
Look to welding and fabricating a piece to replace that.
OR finding that piece good used. Then seperating it from the used shock tower and replacing yours.
Re: Front suspension / alignment question. [Re: autoxcuda] #677971
04/23/10 10:46 AM
04/23/10 10:46 AM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
Seems like you could get someone at one of the Mopar yards to cut one of those off a junk car and sell it to you.
Re: Front suspension / alignment question. [Re: PAINT IT BLACK] #677972
04/23/10 11:03 AM
04/23/10 11:03 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
What year, what car? I've got a good pair from an A-body that I salvaged the inner fenderwells from.
Re: Front suspension / alignment question. [Re: bigsbigelow] #677973
04/23/10 11:15 AM
04/23/10 11:15 AM
S.E. Wisconsin
darepairman Offline
darepairman  Offline
S.E. Wisconsin
I had a cam spin on me while I was disassembaling my front end it broke that 90 due to rusted metal so I welded in a piece of key stock, it works well. Ed
The Event Horizon is on its way
Re: Front suspension / alignment question. [Re: autoxcuda] #677974
04/23/10 11:37 AM
04/23/10 11:37 AM
Ok. Looks like I will try to salvage the piece on the car or make one if that doesn't work out. Thanks much guys
Re: Front suspension / alignment question. [Re: bigsbigelow] #677975
04/29/10 11:13 AM
04/29/10 11:13 AM
How thick is the sheet metal for that plate? I forgot to measure it last night but if i new the thickness I could get a piece of key stock or sheet stock while I am at work today.
