Re: what do you guys think of Edelbrock carbs
[Re: 75dusted]
#677624
04/22/10 09:11 PM
04/22/10 09:11 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I like them. Simple, easy to tune, reliable. I've owned ne sinc the late 80's and currently have three.
[Re: Mr.Yuck]
#677626
04/22/10 09:18 PM
04/22/10 09:18 PM
Thunder Series AOK! Great out of the box no issues Others--ugh..not so much A well tune Holley will run circles around one in any case
[Re: 75dusted]
#677628
04/22/10 11:20 PM
04/22/10 11:20 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
Whats your opinions here on Edelbrock carbs, looking at the Performer 600cfm carb for my 318 engine
The 600 Edelbrock is a fine carburetor. Will work really well with a stock to mild 318.
[Re: Kern Dog]
#677634
04/23/10 04:58 AM
04/23/10 04:58 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Lot of cranking required to top off the float bowl. Until then it's no pump shot, no start.
They seem to run very good on mild engines.
[Re: Magnum]
#677635
04/23/10 12:03 PM
04/23/10 12:03 PM
Posts: 4,793 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Your engine is small in displacement- I would not go larger than 600cfm no matter which brand you buy. It will be tempting to run a 750 but really your warmed 318 will be fed just fine with a 600. You may even consider one of the Summit brand carbs. (They are an improved Autolite then Holley design)
Keep old mopars alive.
[Re: 75dusted]
#677637
04/25/10 08:37 PM
04/25/10 08:37 PM
Posts: 5,447 So Cal
Sinitro
So Cal
My experience with Edelbrock AFBs is that they work fine for stock engines.. Once you throw in a different cam and the vacuum drops they are difficult to get adjusted rite.. Just my $0.01..
