Need help with 440 Cam choice
#676923
04/22/10 01:10 AM
04/22/10 01:10 AM
Posts: 161 Logansport, Indiana
Budman
Logansport, Indiana
My goal is low 11's with a 3500lbs 67 Ply Belvedere 1. 440 30 over 10.1 with Forged Pistons Aluminum 440 Source Heads 2.14/1.81 Old style Crane adj rockers Hedman Headers 1 5/8" Tubes [MY Mistake: They are Dynomax 1 3/4" X 3" Headers] TTI Exhaust with 3" Dynomax Mufflers I can choose from a Torker 440 single plane or a Weind dual plane I can choose from a Holley 850 dbl pumper or a 750 dbl pumper 3200-3500 Stall 4:10 Rear 29" Tall tires Manual Brakes Street driven mostly seldom on the 1/8 mile strip I am ready to buy Cam, lifters, Springs, Chain, & Push Rods. I would greatly appreciate your input.
All MOPARS & nothig else.
Re: Need help with 440 Cam choice
[Re: Budman]
#676924
04/22/10 01:21 AM
04/22/10 01:21 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
As long as you already have the adjustble rocker gear, and considering your goals are pretty serious for a street car (11 second street cars don't happen by accident), I'd go with a solid. Something that has an aggressive profile in the 250 degree range, The MP .557 is an old standbye that still works today.
Also, ditch the 1-5/8" headers. You're giving back a good portion of the HP the Stealth heads are bringing to the table right there. Heck, for $100, the summit ones are at least 1-3/4".
Definately the 850, and though I don't have any experience with either manifold, I'd lean towards the torker for your application.
There's plenty left here that we don't know, but this sounds like a good start in the right direction.
383man
[Re: Budman]
#676925
04/22/10 01:32 AM
04/22/10 01:32 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
My 63 is close to your build. Its a .030 over 440 (446) with stock bottom end and KB quench pad pistons. 906 heads that come in right at 10.0 comp and good quench so it runs on 92 pump. I did the port work on the 906 heads myself. Holley Street Dominator intake with an 850 DP. Hedman 1-3/4 headers with 3" exh and Dyno-Max mufflers. I went with the MP solid .557 cam as I got it real cheap and Isky iron rockers. But I like the .557 alot for my street/strip car. I drive it alot on the street and race it a few times a year. I have a Dynamic 9.5 converter that will flash about 4200 and I use 4.30's with 30 x 9 tires. I have frame connectors and a 6 point rollbar and it weighs just over 3700 lbs with me in the car. Best et is 11.49 @ 116. Sounds like you will be a few hundred lbs lighter then me which would put you in the 11.20 to 11.30 area with the same combo. You also have better heads. If I were you I would use the Performer RPM intake if it fits under your hood. If not the Holley Street Dominator I run is a great street/strip intake for standard ports as is the M1. I thought my 1-3/4 header tubes were small as I never knew they even made 1-5/8 tubes for bigblocks. Good luck with it as it sounds like a real nice combo. Ron
[Re: Budman]
#676926
04/22/10 01:46 AM
04/22/10 01:46 AM
Posts: 855 Brisbane Australia
572B1
Brisbane Australia
My goal is low 11's with a 3500lbs 67 Ply Belvedere 1. 440 30 over 10.1 with Forged Pistons Aluminum 440 Source Heads 2.14/1.81 Old style Crane adj rockers Hedman Headers 1 5/8" Tubes 3" TTI Exhaust with 3" Dynomax Mufflers I can choose from a Torker 440 single plane or a Weind dual plane I can choose from a Holley 850 dbl pumper or a 750 dbl pumper 3200-3500 Stall 4:10 Rear 29" Tall tires Manual Brakes Street driven mostly seldom on the 1/8 mile strip I am ready to buy Cam, lifters, Springs, Chain, & Push Rods. I would greatly appreciate your input.
That looks like a low 12 second combo at best.
I would rethink your combo before ordering a cam.
[Re: Budman]
#676927
04/22/10 01:49 AM
04/22/10 01:49 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Guessing you want a solid FT cam...and the heads are not ported I'd run 260@ .050 on a 107lca and advance it 5°. Lift would be around .570.
Brian
Brian Hafliger
[Re: qwkmopardan]
#676929
04/22/10 08:08 AM
04/22/10 08:08 AM
Posts: 4,743 Moved to N.E. Tennessee
GomangoCuda
1. Sell both intakes and buy a Holley SD. 2. Use the 850 carb. 3. Solid lifter Cam: approx 260@.050 - .550+ lift 4. 1 7/8 headers 5. 9 1/2" converter 6. with the small wheel wells on this body style, I think converter, suspension and tire choices are going to be critical to meet your target. 7. Will your track allow you to go low 11's without at least a 6pt roll bar and other expensive safety equipment? If not then it might be more realistic to shoot for mid - high 11's.
[Re: Budman]
#676932
04/22/10 08:27 AM
04/22/10 08:27 AM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Most everybody likes a cam in the 260 @ .050 range, over .570 lift, and I agree. 1 7/8 headers, 850, single plane, and a very good 9.5 inch converter is needed. A well built converter will stall over 4000, but don't let it worry you, it will be tight enough for the street . You need the higher stall to make the car work. Set this up properly, and it will go low elevens. If you go faster than 11.49, you can figure out what to do at that point. Don't build it worrying about it being too fast, you may regret that.
[Re: gregsdart]
#676933
04/22/10 07:26 PM
04/22/10 07:26 PM
Budman
Logansport, Indiana
Thank all of you for your time and replys. Sorry about the Header mistake. They are Dynomax 1 3/4 X 3" Headers. Low 11's are just a time to shoot for. If I end up running high 11's I would be tickled. It looks as if I should change Intake while I at it. All opinions are appreciated.
[Re: Budman]
#676934
04/22/10 11:00 PM
04/22/10 11:00 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
That should be a bottom 11 second combo, with more converter. Id go at least 4500 flash, if it were me. As far as intake, a buddy went from a Torker to a SD and didnt pick up squat. My combo is close to yours except 452s, more converter, and Im 350 lbs heavier. I too like a cam in the 260 range for your combo. My cam is 259 @.050 and pulls like a muther to 6500. BTW, get with Dwayne Porter on the board and have him grind you a cam!!
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#676935
04/23/10 12:56 AM
04/23/10 12:56 AM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
you should be looking mid 11's or better 509 purple cam stealth heads,pocket port.10.78 comp m1 single plane 825 mighty demon converter is too tight,flashs to 4000 4.1 gears 3754 lbs ran 11.35@119this was a once off meet with this gear(borrowed) have all other times used a 3.9 gear and run 11.4's@118.5 i use 275/60/15 ET Street radials this is my daily driver good luck in your choice Tex PS:i have just ordered a Dynamic 9 1/2 4500flash - look out
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#676936
04/23/10 01:41 AM
04/23/10 01:41 AM
Posts: 637 Kokomo,IN
StripeHOG
Kokomo,IN
my car has ran a best of 7.01 @ 96 in the 1/8 11.13 118 1/4 w/ a torker 1, 4500 stall 9", 10.1 comp, 440 .030 over w/ 915 heads, and a MP .528 solid @ about 3400 lbs you should meet your goal IMO
Andrew Brough D372
1969 Dodge Dart GTS
1.43 60'best
6.82 1/8 98mph
"the light came on and I ran out of talent"
[Re: StripeHOG]
#676938
04/23/10 08:58 AM
04/23/10 08:58 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
dammm you got low 11's w/ a 528? Makes me almost sorry I got rid of mine for the bigger bump stcik.
