Info. about AFB carbs #67674
06/04/08 08:20 PM
06/04/08 08:20 PM
Great White North
71Furious Offline OP
super street
super street
Great White North
Hello I recently purchased a 440 AFB carb. that needs a rebuild. I would like to do the work myself however I was wondering if anyone knows of any sources of info. available on the Internet.
Thanks in advance!!
Re: Info. about AFB carbs [Re: 71Furious] #67675
06/04/08 08:28 PM
06/04/08 08:28 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
AFB or AVS?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Info. about AFB carbs [Re: Rug_Trucker] #67676
06/04/08 10:28 PM
06/04/08 10:28 PM
Alabama
swapdaddyxx1 Offline
Alabama
An afb is actually a pretty simple carb,just note carefully how everyhing goes when you take it apart. Be sure to get it clean,and make sure all the passages are clear. The rebuild kit will have specs for the float levels etc when you put it back together. I have always had good luck rebuilding afbs and avs. Not done as well with thermoquads,but its a good carb when you get it right.
Re: Info. about AFB carbs [Re: swapdaddyxx1] #67677
06/04/08 11:01 PM
06/04/08 11:01 PM
2 things I do is save every old gasket during teardown to be sure I replace them with the exact same one as kits sometimes have several & some of them look real similar but are different & I measure each setting(float level)etc as I tear down the carb that way I have a baseline to work off of when going back together because a carb will need to be gone thru but the settings dont change hardly at all & if I find I need to make drastic changes in settings (ie float level) that means I am probably looking at the wrong specs.If you have your own bucket of carb soup soak the pieces for a couple of days.jot down a few notes on which screws go where etc on dissassembly, several minutes doing that saves ALOT of guesswork later.
Re: Info. about AFB carbs [Re: 71Furious] #67678
06/04/08 11:25 PM
06/04/08 11:25 PM
Rug_Trucker Offline
Rug_Trucker  Offline
Ziplock baggies and Sharpies are good ideas.
Re: Info. about AFB carbs [Re: 71Furious] #67679
06/05/08 01:00 AM
06/05/08 01:00 AM
Great White North
super street
super street
Great White North
Thanks for the input guys!! I should have checked the tech. archives before asking however several of the responses have been extremely informative.
