Need info on HEMI head #P3690483 #676734
04/21/10 07:39 PM
04/21/10 07:39 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
What can you tell me about these HEMI heads? I know they are older Keith Blacks. They seem to be hand ported and the valve covers have Dick Landy stickers on them. Is there any such thing as a typical flow range on these heads after porting? They have 2.25/1.90 valves.
The exhaust pattern does not look like the stock pattern to me. Is it likely that these heads have the D ports? Would they be the raised port? Where does that put me on header availability?
I would like to put this engine in my 70 Cuda. How many issues will these heads add to the install? And how about streetability on a 500" engine?
I would really appreciate any and all info on this. (You can see how little I know.) And that will probably lead to more questions.
Thanks!
Master, again and still
Re: Need info on HEMI head #P3690483 [Re: DaveRS23] #676735
04/21/10 07:49 PM
04/21/10 07:49 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
DLI usually stamped the heads if they touched them.
Re: Need info on HEMI head #P3690483 [Re: DaveRS23] #676736
04/25/10 03:42 PM
04/25/10 03:42 PM
Maple Ridge, BC, Canada
N
NitroFixx Offline
NitroFixx  Offline
N
P/N P3690483 are rocker arms for a Colt 4 cylinder engine.
Re: Need info on HEMI head #P3690483 [Re: NitroFixx] #676737
04/25/10 07:30 PM
04/25/10 07:30 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Actually, I listed the block number by mistake. Brain fart, I guess. But P3690483 is the number on the block, right beside the Keith Black name. I just went over and double-checked it.
Now, the head number is P4120711. I called Keith Black and talked to Ken. What a nice guy and super-helpful. He got me up to speed on the items.
FYI; the heads are raised "D" port water heads and since TTI makes headers for them that fit my car- they will work great in my Cuda.
