Steel billet 904 Front drum anyone?? #676624
04/21/10 05:43 PM
04/21/10 05:43 PM
Rancho Cucamonga, Calif.
P
PUNK Offline OP
PUNK  Offline OP
P
We are looking to replace the aluminum front drum in our 904 trans with one that is more durable than the race only aluminum piece yet safer than the explosion prone stock drums. I cant seem to find the steel billet front drums for a 904, only 727s. Is there anyone that make such an animal? Or is it time to put a 727 in it and slow it down. With all things being equal, does anyone know what the differance E.T. wise a 727 vs. a 904 would be? We will be stepping up the 394" Edelbrock headed engine to a 411" Indy headed engine so we will be making considerably more power, we just want the trans to be a little more reliablewith less maintanence. Street driving a trans with an aluminum drum plays hell on the drum. Frequent trans oil changes is getting old as well.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Steel billet 904 Front drum anyone?? [Re: PUNK] #676625
04/21/10 05:59 PM
04/21/10 05:59 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Depending on a number of factors( and who you ask) a 904 is going to ET anywhere from 1 to 2 tenths quicker.
I think about 1.5 is probably more common than any other, that i have heard of.
A few years back i swapped out a basic 727 with stock internals, for a full roller unit with an aluminum drum, lightened sunshell, etc.
The new trans proved to be ultra reliable, but i saw nothing on the ET slip from the torrington bearings, lightened internals, etc.
Long stort short, no matter what is done to a 727, its in fact going to be a good bit slower than a 904.
might want to check with SMR regarding a billet steel 904 drum.
His site seems to imply he has them
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Steel billet 904 Front drum anyone?? [Re: PUNK] #676626
04/21/10 06:32 PM
04/21/10 06:32 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
you have a PM
Re: Steel billet 904 Front drum anyone?? [Re: PUNK] #676627
04/21/10 07:23 PM
04/21/10 07:23 PM
Lehigh Acres, Florida
rickstershemi Offline
Re: Steel billet 904 Front drum anyone?? [Re: PUNK] #676628
04/21/10 08:00 PM
04/21/10 08:00 PM
b.c. can.
W
wasteddays Offline
wasteddays  Offline
W
b.c. can.
tcs makes one. #123800s $574.50 looks good!
Re: Steel billet 904 Front drum anyone?? [Re: wasteddays] #676629
04/22/10 06:51 AM
04/22/10 06:51 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
John Cope told me he had some and so did A&A. I will be having one of them build me a throw down 904 soon.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Steel billet 904 Front drum anyone?? [Re: Jacob Pitt] #676630
04/22/10 07:53 AM
04/22/10 07:53 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
The reason that the 904 billet drums aren't plentiful like the 727's is because the factory steel 904 drums aren't a problem. The diamater is so small, they don't have the mass/rotational inertia to pull themselves apart.
I continually ask, and I have NEVER seen or even heard of a 904 drum coming apart. They are just too small to do so...
Re: Steel billet 904 Front drum anyone?? [Re: dizuster] #676631
04/22/10 11:59 AM
04/22/10 11:59 AM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I agree and it's typical how NHRA lumps everything together making it harder for the racers. 904's don't blow up and yet we still have to have shields/blankets. Probably because the tech guys can't tell the difference between a 904 and a 727.
I have broke a couple 904's but never blew one up and I have never heard of it either.
Has anyone ever heard of a 904 blowing up?? Anybody??
SRT DEMON ONE SEAT
Re: Steel billet 904 Front drum anyone?? [Re: Ron Silva] #676632
04/22/10 12:13 PM
04/22/10 12:13 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
I did a post on this 2 years ago for someone to give me any info if they ever seen one blow up or heard of one blowing up and I did not get one response. I have always run 904s with my smallblocks and never had that kind of a problem.
Re: Steel billet 904 Front drum anyone?? [Re: b1dartsport] #676633
04/22/10 02:51 PM
04/22/10 02:51 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Since the clutches are smaller in the 904 there is less clutch area to absorb the torque. More clutches help as does more line pressure but some of the billet drums for the 904 offer a larger apply piston so there is more area on the apply so more clamp force for the same given pressure. I guess what I'm saying is although there may be little to no chance of the drum exploding due to a sprag failure like the 727, then the additional piston area may be a good reason to consider the aftermarket drum for the 904.
Re: Steel billet 904 Front drum anyone?? [Re: PC-CHARGER] #676634
04/22/10 04:13 PM
04/22/10 04:13 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
I have had the same 904 in use since 1993, the only failure I have had was the rear drum separated...kind of hard to explain...but it was just a perfect break in the drum...you had to see it to believe it...
In fact at MATS, the tech guy asked my daughter about a shield since the dart runs low 11s, and said something to the fact about running a TF without a shield was dumb...I told him it was a 904 not a 727 and he was confused.
Tony
70 AARCuda Vitamin C
Re: Steel billet 904 Front drum anyone?? [Re: 70AARcuda] #676635
04/22/10 04:25 PM
04/22/10 04:25 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
TCS has the "blow-up" numbers on the 727 drums ....stock OEM, steel and alum ....
Do they also have #'s on the 904 ?
Re: Steel billet 904 Front drum anyone?? [Re: dOoC] #676636
04/22/10 05:09 PM
04/22/10 05:09 PM
PA
moparacer Offline
moparacer  Offline
PA
Never seen one blow up either.
Run them for years and know other who have too.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Steel billet 904 Front drum anyone?? [Re: moparacer] #676637
04/22/10 05:18 PM
04/22/10 05:18 PM
P
PUNK Offline OP
PUNK  Offline OP
P
About a 904 not blowing up....The stock Eliminator 340 Duster that I owned had one blow up when the prior owner had the car. The floor board in that car was absolutely DESTROYED! It looked like it drove over a bomb in IRAQ. I asked if it was a 904 and not a 727 and the prior owner assured me it was a 904.
My brothers car is too nice to have that happen to the floor board. With my luck, the 904 that I would put in his car would be the 1 in a 1000 that would blow up. If it wasnt for me owning a car that had one tear up the floor, I too would say that I have never seen one or heard of one blow up.
Re: Steel billet 904 Front drum anyone?? [Re: PUNK] #676638
04/22/10 06:07 PM
04/22/10 06:07 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I`ve ran 904s for over 25 years and have broken them but never blew one up. Most of them last about 4-5 years before we rebuild them even then they look pretty good inside. I have a CSI shield its a pain taking the trans in and out with it but if I ever do blow one up I`ll be glad I had it. I`ve been as fast as 10.40 with a 1.40 60ft with my present 904 set up.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Steel billet 904 Front drum anyone?? [Re: Ron Silva] #676639
04/22/10 07:33 PM
04/22/10 07:33 PM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
Wow, that's perdy. Who's product is this?
DC
Re: Steel billet 904 Front drum anyone?? [Re: dc426] #676640
04/22/10 09:36 PM
04/22/10 09:36 PM
P
PUNK Offline OP
PUNK  Offline OP
P
Thats Rons 904 built by ProTrans in Lancaster Calif.
Re: Steel billet 904 Front drum anyone?? [Re: dc426] #676641
04/22/10 09:43 PM
04/22/10 09:43 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
If it's peace of mind that you are after then by all means put one in,,I have been running a stock drum for many years with no failures, 12 years in a low 11 second dart, and last three years running in the low 10's high 9's in that same car, I know it took some tran's company's years to even make a steel drum because of no/low demand.
