Re: How do you check valvetrain operation??
[Re: MoparforLife]
#676225
04/20/10 10:27 PM
04/20/10 10:27 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
Take off the valve cover and start the engine.
This may be a stupid question, but won't oil go flying everywhere?
[Re: stumpy]
#676227
04/20/10 10:48 PM
04/20/10 10:48 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
If you are worried about that then just cut the top out of a valve cover and bolt it on. You can then watch the rockers work and not get oil everwhere. Oil won't squirt all over and it will drain back down the returns as normal.
I guess my only reservation about it is because I've never done it before. If it's just a little oil that gets spray around, I don't care. It it starts gushing out, I don't imagine that's a good thing. Never mind the fact that I don't have a spare set of valvecovers.
[Re: Pat_Whalen]
#676228
04/20/10 11:02 PM
04/20/10 11:02 PM
RapidRobert
not likely an oiling prob. Pull the VC and start w a good visual inspection & see what you uncover
[Re: RapidRobert]
#676229
04/21/10 06:24 AM
04/21/10 06:24 AM
Posts: 15,487 Florida
scratchnfotraction
yea pat just pull the covers and run it a short time to see if it oiling them
you wont have that much of a mess for a short time
look to see if the are dry,if they are dry pull the shaft and check the rockers for scuffing on the shaft
