valve spring pressure #67586
06/04/08 05:41 PM
06/04/08 05:41 PM
Sterling Heights, Michigan
My340Duster Offline OP
super gas
super gas
ok guys I just ordered the racer brown cam today but I need to check my spring pressures. How do I do this and can it be done on the motor without taking it apart. is there a tool that I can buy to do this?
Ron
Re: valve spring pressure [Re: My340Duster] #67587
06/04/08 06:06 PM
06/04/08 06:06 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Worry as much about travel from installed height to coil bind and the retainer to guide clearance as much as the pressures. Coil bind or guide to retainer interference is very real and very costly. IMO always match the valve springs to the cam.
