Re: big block crankshafts measurements
[Re: ryan053]
#67575
06/04/08 06:34 PM
06/04/08 06:34 PM
Posts: 25,933 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Besides turning down the main journals to fit the B block, the counterweights need to be cut down to a diameter of 7.250". Your counterweights are still the original RB dimension.
[Re: ryan053]
#67578
06/05/08 06:34 PM
06/05/08 06:34 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Send it back!! they goofed in the machine room. Don't let it become your problem.
[Re: ryan053]
#67582
06/05/08 07:40 PM
06/05/08 07:40 PM
StealthWedge67
Puyallup, WA
Please give me their name so I know who NOT to do business with!! You can notch the bores instead of cutting down the counterweights, it works and has been done many times before, but I would call it the wrong way to do things. Moreover, they most certainly should have forwarned you of this prior to taking your order!! Personally, If they didn't finish the crankshaft properly, I'd post their names here & at every other board you can find with a big fat "BAD-GUY ALERT"
[Re: ryan053]
#67584
06/05/08 07:59 PM
06/05/08 07:59 PM
A few points . 1 st The thing that makes the 440 crank in the 400/383 block work so well is that the counterweights get cut down. It takes almost 4 lbs off the crank. Makes it rev much better. So to take the material out of the block weakening it is just plain crazy. 2nd dont let nmanufacturers off the hook on screw ups. yes we all do screw up and if they are having to many they will correct the problem or go out of biz. But a 383 stroker crank has to have the weights cut down and I believe Muscle motors sells there kits ready to install. 3rd 3 grand for a properly done stroker isnt much money. Nothing is free the cheaper you buy race parts the more work needed to make them fit or the less reliable they will be. 4th 440 sourse has had there issues also going from one cheap company to the next wont solve the problem. back to the start Hold the company responsible for their mistake. what ever it takes. Other wise they will keep throughing cheaper and cheaper stuff out there if there is no consiquence to themselves.Thats the American way man. Thats why we have Walmart, expensive gas and no manufacturing jobs.
